Brake upgrades
830king
191
Central MN
I bought Russell's braided lines I see it replaces the soft lines just in the 4 corners, has anyone has a braided line made for the soft line from the frame to the center of the rear axle that splits to each side?
I've put 2 of the Russell kits on and they both came with 5 hoses. Both were for classic body style tho.
Sent from my SM-G930V using Tapatalk
gmduramax
Shits broke
Jun 12, 2008
4,082
252
Nor cal
Ok so I’m finally happy with my brakes. Just got the LML master cylinder on and I’m impressed. Much less pedal travel. The brake pedal is slightly harder, but I have much more confidence driving. Getting it to work is a pain in the ass but shouldn’t be bad now that I’ve figured it out.
Get an LML brake master cylinder. Find a metric double flare tool. Find 14mmx1.5 inverted flare to 6mm tube fittings. Drill out the fittings with a 17/64 drill bit. If your fittings aren’t threaded all the way to the top. Cut off the top and and use a drill bit to bevel the fitting. Cut only the flare off of the factory lines (make sure you cut it straight) remove factory fittings. Install new fittings, and flare the line. Install everything :thumb:
gmc502
468
13
where did you get the 14mmx1.5 inverted flare to 6mm tube fitting?do you know the thread size of your original master?
N2BRK
2,066
399
So LML hydro unit and LML master = better LMM brakes for low bucks? Cool! Thanks for coming back instead of letting the thread die! Always nice to see something like this have an ending instead of left hanging! :hug:
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
I have the everything here to make the master work, just haven’t found the time to mod the fittings, and re work lines to make it work. BTW thanks Anthony for the help awhile back on where to find the fittings.
gmduramax
Shits broke
Jun 12, 2008
4,082
252
Nor cal
This should work on 01-10 trucks not just LMM. I think I have less than $1000 into everything and the truck stops great. I’m considering SSBC’s calipers now.
gmduramax
Shits broke
Jun 12, 2008
4,082
252
Nor cal
Yea no problem. I’m still trying to find fittings that don’t need to be modded, or maybe have some made.
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,512
35
LA
Which ones?
Sent from my SAMSUNG-SM-T337A using Tapatalk
countrycorey
Jan 30, 2010
1,512
35
LA
Those look good, I was wondering how they would do on our trucks. What ever happened to their v8 calipers?
Awenta
4,090
CT
I’ve considered those but it isn’t much more to get wilwoods at that point.
torqued2dmax
646
Brookville, PA
gmduramax I got the part # for the hydro boost 1780853 but I need the # for the master cylinder . I have an 05 3500 drw , if it matters , thanks for a great post on upgrade !
