Brake upgrades
gmc502
466
12
well I got the master,its big,maybe 3" longer,it hits the radiator hose,think I can shorten it by the radiator and make it fit.will be reflaring my lines w/ the new fittings tomorrow,hope this is worth the effort.
torqued2dmax
646
Brookville, PA
I see rock auto is out of the AC 2011 power brake booster , did you get one of those also ?
Dozerboy
4,896
473
TX of course
Give us some photos please. I don't have much room around my 3" hot side pipe and my stock master.
gmduramax
Shits broke
Jun 12, 2008
4,076
250
Nor cal
I didn’t think it was any longer than my factory one. I’m going to check the length on the 04 I have sitting at the house.
gmc502
466
12
It will be interesting to see if the 2002 37mm bore power brake booster , that is oem in your truck, will accept the 2011 38.1mm master cylinder . Let us know ! You may be needing to replace the power brake booster with a 2011 .
oh its gonna except it,come this far,tomorrow I'll put the new fittings on my brake lines.Tat will be tough,not a lot of room to work.
gmc502
466
12
so I got it installed today,heres some pics of what I bought,made/modified.
heres the fittings
then old fittings beside unmodded ones,sorry,didn't take pics of the finished ones,but the look like the 2002 fittings
gmc502
466
12
heres the comparison of old verses new,new one is 2 5/8" longer.
gmc502
466
12
I had these 2 flaring kits,,there designed for tight spaces,if you look close,you can see the tool is installed on 1 of the lines.
also,gotta love gm,the brake lines are a touch bigger than 6mm,made for installing the flare tool a bit touchy,a little sanding w/ Emory cloth and it was good to go
gmc502
466
12
one line down,harder line to make up next.needed to straighten the line a little to get the flaring tool on.
btw,this line is tough,standard flaring set up could be a biotch to use.
gmc502
466
12
like I'd said,master was gonna hit the upper radiator hose,this pic shows how much I trimmed off the engine side,basically cut the hose one the clamp line thats towards the radiator.
gmc502
466
12
now ,was it all worth it.time will tell,I need to get thru the winter on these brakes which are toast.
but at least my truck stops again.
spring time will be the big test,when everything is new,again
torqued2dmax
646
Brookville, PA
Good job , glad to see you got it back together , nice pics and you got the hard part done if you ever want to do the 2011 power brake booster down the road . Let us know how it feels compared to the old one when the roads get better . Thanks for keeping us informed !
