Seams no one local to me stocks kroil But everyone will order it.Soak it down with penetrating oil. I like KROIL oil, the oil that kreeps. Haha Or just mix up some acetone and trans fluid.
I'll call around to a some local.Adam, try a gun shop or local AC shop for the Kroil. I have seen it in both of those places before.
Long road so far and still to go, but she does look good.
Because it 2x whatever the cost of the stuff they normally sell is. I just purchased some this last weekend IronicallySeams no one local to me stocks kroil But everyone will order it.
Thinking it was a bad flare job, made a video and the DS line leaks, I didn't check before pulling it apart, granted it needed replaced anywaysSo were you able to fix what is leaking or you need to replace the mechanical part of the module?
Meh, if I can keep the wind off I'm pretty good, for another 20-30°You better hurry up or it’s gonna get too cold brother!
That's normal on this body style truck. I'm not sure why they changed it, but I've noticed it before too.Another note brake lights only work when the key is in the on/run position..
Thanks for that feed back, appreciate itThat's normal on this body style truck. I'm not sure why they changed it, but I've noticed it before too.
