610
You sure that frame you bought wasnt bent?
If it is bent, it's bent a whole lot less than the one I pulled out. When I pulled the radiator core support body mount bolts out everything on the front clip jumped back the the DS on the original frame. As I was hit on the DS going to the PS.
I'm sure there is a lot of stuff slightly "tweaked"
Things like DS fender needs to be tweaked back so my headlight assembly mounts correctly.
I haven't even mounted the hood yet 🫣
1,117
Put the hood on it and square up the sheet metal. That fender brace on the fire wall could be bent as well as a few other things. That should give you a better picture of what's going on.
Reactions: malibu795
610
I'll be hunting for another hood, I pick this up for sub 100.00 iirc
Reactions: 1FastBrick
610
So this came up in my FB history, last dmax I blew up was 7 years ago.. failure was ripped #4 main web on a lb7/LLY block that was running main studs.
I've got 2 LBZ/LMM based dmax engines here, one needs a block other is a LMM block that needs bored..
One of the comments was @Chevy1925 mentioning getting a LML (11-16) block
How interchangeable is it?
Should I start keeping an eye out for one?
1,117
For whatever reason the LML seem to fetch a Premium but I don't know why. Supposedly a stronger casting from what I am told.
I wouldn't pass up an LBZ/LMM block though.
I guess it depends on what your doing with it.
2,207
Yeah, increase in webbing and I think thickness in a few areas. Supposed to be stronger.
I'm pretty sure they are compatible with all prior generations with no significant differences. It's more about what gets bolted onto or into it
1,117
I think the only major was the thread for the oil sensor. I see an adaptor for sale to use older block with newer sensor for a 2011+ wiring.
https://dirtyhookerdiesel.com/i-240...pressure-sensor-adapter-fits-2011-sensor.html
You can also go the other way too.
https://dirtyhookerdiesel.com/i-240...ure-sensor-adapter-fits-2001-2010-sensor.html
610
Little of everything, HP limit is what ever stock injectors support with a sportsman CP3 feeding them. That's what ~600 at the wheels? Plan on swapping nozzles to 7 hole via Industrial or DDP which are like 10-15% over
Definitely not planning on towing like I did with my LMM dually
610
610
Got the PS fender aligned, DS better fitting,
The in-radiator transmission cooler fitting are metric vs SAE running M22-1.50 vs 7/8" got a new set of -10 adapters
Pickup up a little trans cooler for the Power steering system. Found out I used all my -6 to M14x1.5 fittings..
Looks like AC upgrades are possible, the condenser from my 01 2500 burb fits, will most likely need new lines.
The burb condenser is ~6" longer.
The rear AC in my burb has been deleted for a while and no freeze up just running the front.
Also trans line routing.. does the transmission outlet run into the top or bottoms radiator fitting?
Edit googled found a PDF from FPE
Reactions: SmokeShow
