Best Single CP3
Righteyeblind
712
Fairbanks, AK
If your pump in the valley has a mechanical problem and completely you will still make it home. At least I did... You will just waste a full tank in 2 mile.
I tried a modded single with a 60% over injectors and a 2300ms tune held 23.5k
Definitely going duals for next year
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
99 % of the time that the case , I have had one truck though that had a bad Cp3 with duals and the truck wouldn't even start . I still think duals are more reliable than one modded single but I wouldn't hesitate to run a modded single on my DD .
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I ran a mid 11 sec pass with one cp3 in the valley grenanded.:D
pass and wash the grease off at the same time:spit:
VeeAte
going for 10s
Dec 7, 2010
177
ocean springs, ms
I would go with the duals , I have tuned several trucks running modded pumps as singles , they do good , but wont produce the same amount of fuel as a dual cp3 setup when comparing how much pluse width can be ran before dropping the rail down . I am running an II 120% pump in my duals and it has held up fine , and the truck holds perfect rail pressure usually even on the biggest tunes .
x2, i have the wicked stage3 and 60% overs, and will be adding my stock cp3 back to it. My rp will hold 25k on my 2360pw tune, but trying to squeeze a little more power out of it by bumping the pw to 2450+ my rp falls to 23k and i lose a mph at the track. I would just go duals right from the start.
cobb
Mar 12, 2010
22
50
Ruth, MI.
I went with an II 85% over because I wanted to look stock without drawing too much attention. I've had it on two years now and has worked fine as a dd, it held good pressure till I started wandering over 650 hp. I'll be adding a dual fueler this winter!
cafryer
May 5, 2011
1,074
Utah
I have heard good and bad from both. I went with the II kit which is made by ppe and hsvent had any issue with it.
TrentNell
Jul 7, 2008
7,543
slc tuah
I have ran as much as 2950 usec with 130% overs , and rail pressure was 1k over desired , almost threw back in the old stock injector 3250 race tune in :D
I've heard different things about ATS and PPE duals, which one would be a good choice? (I know some guys have already stated what they run).
They are both good kits and each has things I like about them better than the other .
2,064
Idiot question of the day: when you're talking about the Wicked (Motorsports) Arson pump, are you all talking about the boxes of parts to modify your own CP3, or an actual modded pump from them?
I wonder if simply buying the box of parts to refresh my CP3 would be a good idea, thats why I ask.
