Best DD Engine Build??
1,957
Would you use a type of header or just stock manifolds?
I guess that money could then be used on a set of Mahle pistons.
13,736
806
I have stock passenger side, LML driver side, and ProFab 2" up pipes on my motor.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
i like this Tom except for 800hp id pass on the uppipes/manifolds and use something other than stock pistons.
X2. People making double the hp with damn near the same size as stock. Only benefit of up pipes is the stronger bellows. Witch correct drive pressure should keep that in check
5,927
bigger manifolds/up pipes really come into play when you are running a restricted turbo size but driving the heck out of it for max power. obviously the turbo hot side would have to outflow the stock up pipes (something in the 472 range and up or certain sled pull setups), then you gain the benefits of the higher flow and lower drive pressure from them. a stroker motor would see a benefit from them as well
Twins or large turbos not being pushed to extremes usually keep drive pressure in check due to staying in their map.
3,732
300
I built mine with 900+ HP in mind, but at relatively low torque, so probably more in line with a normal 700-800 HP build.
  • Stock block, .020" over (300k miles, it was at service limits)
  • Stock 300k mile LB7 crank (it magnafluxed as good), keyed
  • Carillo rods
  • Mahle race cast pistons with valve reliefs, 16.5:1 (probably should have stayed stock CR)
  • Stock flexplate (looked good, and relatively easy to replace when needed)
  • SoCal / ATI damper
  • Fully (externally) balanced,align hone on the crank journal, all new bearings
  • Stock 300k mile oil pump
  • Comp Cams most absurd cam (this might have been a mistake, but it sings at 5000 RPM!), normal fire order (I don't buy the AF saving the crank argument personally)
  • Wagler LB7 head (cast-in injector cups)
  • SoCal valve springs (any should work, I had these laying around)
  • +75% SAC injectors (probably will have to go up to 150% or more when I get air)
  • Single S371 turbo (all I could afford at the time)
  • LML driver side manifold, stock passenger manifold, RDL up-pipes
  • ARP fasteners everywhere
That setup makes 660 RWHP / 970 lb-ft. The low torque is by design, and was setup for my future plans.
The goal down the road is compound turbos, probably a 71 mm and a 90+ mm, so I can push 5000 RPM instead of choking out at 3600 RPM. If I can hold the same ~970 ft-lb up the rev range with the bigger turbo setup, that'll be a bit over 900 HP, which was my original goal.
gmduramax
Shits broke
Jun 12, 2008
4,082
252
Nor cal
Doesn’t the lml manifold flow more than 01-10 manifolds? I thought I remember seeing where people would port the 01-10 manifold before it goes into the up pipe and the lml manifold you didn’t need to.
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
Any amount you over bore will help with airflow, unshrouding the valves. It would be minuscule, and extremely expensive/hard to measure gains but its a major reason I wouldn't be afraid to over bore when replacing pistons. Do not waste money on exhaust parts before budgeting for motorsports pistons either.
Sent from my SM-G960U using Tapatalk
20dmax08
57
Wouldn’t the benefit of lower egts with manifolds and up pipes be worth it?
5,927
But do they? That claim could vary by a large margin as there is so many different ways to make power
13,736
806
More fuel and more power means higher EGTs. There is no way around that.
Nickracer9
203
Put your money on the best internals you can afford(rods+pistons+studs) otherwise it will always be in the back of your mind every time you use your truck on a long haul. FYI I didn’t gain anything from manifolds and up pipes on the dyno in the 600whp range.
1,957
I found it interesting the reasons given for mani's and up's. Considering how hard I pushed my stock turbo, it makes sense they helped me.
20dmax08
57
Interesting! This good thread and full of knowledge! Learning quite a lot!
Blackmax123
683
central Pennsylvania
Incorrect. The 01-10 were choked down to fit an application that GM never ended up using. The lml is the first year to have the manifolds not choked down like the 01-10
Sorry ment to type isn't choked down.. lol
My last lml build consists of.
Stock block, 40 over, mahle race casts, with valve reliefs
Billet mains, callies compstar crank, wagler rods, studded mains, head, and rocker bridges, dorman oil cooler, DP water pump, wagler stg 1 af cam, wagler valve springs, had the heads gone through. 10mm stroker cp3 swap. I did get a set of prefab manifolds and uppipes because I traded my stock lml stuff for them.. maybe a little over built for my needs but hoping to not have to ever do it again.
