Banned
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
What exactly is a. "Troll Bot?":confused:
These came from Russia. They are computer programs that can register to the board and make bogus posts. We try to kill them ASAP as they can actually infect the software with virus's. We lost our board fuzzydiceracing to bots :mad:
Bluemax
Sep 25, 2006
846
Missouri
I read that thread and found it interesting that Cole is using some very clever wording about his stroker kit, sounding like it's actually better than stock.
When you stroke an engine by offset grinding the rod journals, you must remove metal from the crank at the same rate you want the stroke to increase.
So if your journal is 2.5" in diameter, and you want to add 0.300" stroke to it, you have the grind the journals down .300". That's 30% LESS rod journal material as well as 13% less bearing area. If my math is right.
Exactly how much stronger does that make it? None. It makes it far weaker. Even if that's not the area the cranks are breaking at, reducing the rod journals makes the crankshaft flex more. 30% more.
Not the road I'd go down to solve breakage problems, or even use on an engine with breakage issues.
Whether the SoCal stroker is the cat's meow or not, trusting someone's opinion on it who thinks cutting that much off the journals is a clever solution is silly.
The cranks that I have had offset ground were built up first, then offset ground to give them the extra stroke so we still used the original journal size and factory bearings, Then some used regular and some used custom rods. If that's the case and they are doing this, is it still going to be weaker than stock? Still have the same amount of material on the crank just moved a little bit, so it could be re balanced and ready to go? I've never seen it done like you were describing, that just seems like kind of a silly way to do it to me, unless I'm picturing it wrong.:confused:
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Yeah, love the cute messages and the WARNING!! YOU WILL GO TO PRISON OR THE GAS CHAMBER IF YOU READ THIS WEBSITE crap.
IIRC, CompetitionDiesel.com says:
Welcome back! We've missed you. Please take a minute and post something.
THE STAFF HAS BANNED YOU FOREVER. GET THE HELL OUT OF HERE!
:D
:rofl: I got that one there, defenatly another site that has double standards!:D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I'm not sure about weld up cranks. It is probably is important who does it. Welding puts a lot of heat into the material, and it can start cracks if not done right.
15,681
233
I don't know much about weld up cranks but I do know quite a bit about weld up parts on transmissions and they are never as strong and fail most of the time.
UNBROKEN
Mar 30, 2008
565
I went and looked...that is in fact NOT the message you got when you were banned.:hello:
If "double standards" means banning someone who repeatedly attacks a Moderator untill said Mod gets fed up and hits the button....then so be it.
I would have done the same thing. I have better things to do than fight with a member who doesn't wat to be there anyway.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
This board is the same age as CompD. No moderator here has ever had to use banning as a form of moderation. There are boards with over 30k members who don't ban members either.
Just a different mindset. A website is it's content and members. Content is derived from the members. So banning members is like shooting one of your cows when it kicks you while you're milking.
You folk just need to milk it better. :D
UNBROKEN
Mar 30, 2008
565
We didn't lose much Pat...he only had 14 posts and most of those were defending you. LOL:hug:
UNBROKEN
Mar 30, 2008
565
We have no plans to change it at this time. :D
Most banned members find their way back through other usernames anyway.....right Pat ? :eek::rofl:
UNBROKEN
Mar 30, 2008
565
Most your members don't have 14 posts. :D
We're just a bunch of unedumacated hillbilly's...we can barely find the keys to type anyway. 14 sounds about right....most of our guys are too busy winning races to worry about posting. :D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Heck, why would I post there, I don't even know anything about 12v's? :confused:
And I'm not selling anything they can use. That's the only reason you let Hogue stay, right? As soon as he stops carrying 12v parts, he's a goner. :D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The average ET here is lower than any other diesel board. Heck, I hear the world's fastest production diesel pickup even hangs here.
Even though you raise our average ET, you are welcome here... :hug:
:D
