Anybody try a sump in the stock fuel tank????
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Question Id like to pose to everyone....
If you were to stick with this same type design (bottom mounted sump), what would you do to improve/modify the design?
Here is the current Hellmann unit:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Matt, IMOP they are fine right as they come , I have ran one and had no problem holding 26k rail pressure on a 2900 pulse width and 45% over injectors , its not the rocket science that some guys are making out to be ................................................its just a fuel pick up and works great . only thing that would be nice is a fine mesh screen built in a few inches off of the bottom to stop any big particles , even though my tank was spotless inside even after 8 years and 70k miles .
9,906
152
Matt, as I said before-a small standpipe that goes just a little higher than the bottom of the tank and a 1/8NPT threaded hole in the bottom for a petcock to drain water. Even if it was just an option.
Not all of us get our fuel from the fuel station if you know what I mean.;)
Dozerboy
4,934
513
TX of course
X2 on a screen
I would like to see a more low profile version with kind of a dome shape being flat on the "back" side for the fittings. I would love to get a sump over messing with the stock pickup, but I don't want to risk catching it on something. I know it has to be big enough to get the fittings on, but I would think you could cut it down to 11/2"-13/4". If this unit is feeding guys with duel CP3s I sure a bit smaller one would feed us stockish guys just fine. And from the look of our fuel tank with a 1/4 of a tank of fuel I don't see sloshing let any sort of a sump not mounted in the front of the tank go dry. I would think you could get way with thinner material too after all its mounted to a plastic tank. If that could cut cost any.
TrentNell
Jul 7, 2008
7,543
slc tuah
X2 on a screen
I def see what your saying dozerboy , but anything that would rip this off of your tank , may be hitting the fuel tank anyway IMOP , we are talking about 2.5 " it hangs down , while i do agree that it is something that should be considered when buying , I dont see it being a real issue for 98 % of people. My guess is the same scenario would take out the tank in either scenario , JMOP i could be way off base on how most use there trucks .
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
X2 on a screen
mine feeds duel cp3's both with and wiothout the liftpump running, no issues so far :D
