But I still did it...
If your smart about the build and assemble it yourself I see 5k being easily done.
Exactly. And the OP is only looking for 700hp. I'm sure he won't be spraying a large single either oke:
till he wants more :roflmao:
they ALWAYS want more:angel:
True, but it's hard for me to tell over the internet how easy some people give in to peer pressure
I personally dont think it will last long at a TRUE 700hp motor. Maybe a generous Dyno. Yes a tuner will keep the torque down to help but what fun is that?
That's why I went balls out. Only part I skimped on was the billet crank..
Thanks, any benefit to including an alternate fire cam with stock heads? Guess I should have mentioned I probably have all the seals laying around already too, pretty much just considering hard parts.
If I can keep the std. bore, I could delip the stock pistons myself, but is it worth it to get new delipped pistons over machining the old pistons?
What do you all think about this kit, comes out about $700 over budget with the bearings, studs and fingers pistons, but are the fingers worth the extra $750 over delipped?
http://creaturesofthenightperforman...an-Crower-Rods-Pistons-Bearings-P5661465.aspx
Why not? Only talking long block and no labor costs since I'll do all the work.
Maybe put your LB7 heads on an LML short block
Change the reluctor wheel
Buy some head studs
I think that's all you'll need? Right?
You have to ask yourself how much risk you're willing to accept. Yes some guys have gotten away at 700 hp w/ lbz rods and cut lb7 pistons but some have also had them fail. They can live forever if you detune the low end but where's the fun in that? If I were to do a budget build I would do the following which will likely come in around 6k w/o machine work.
- Fingers cast oval bowl pistons
- The cheapest of Carrillo, Manley, crower, or Wagler rods
- Head studs
- Main studs
- Clevite H bearings
- Oem cam bearings
- Key crank, cam, oil pump
- Pinned water pump
- Dowel mains
- Align hone
Plus have head and block checked out and whatever machine work is necessary. I would also try and stretch the budget a bit to include MA pushrods and new valve springs. This not only minimizes/eliminates most risk but gives you room to grow.
I haven't seen any mention of what you have done to your trans, you don't want to blow your budget bulletproofing the motor only to have your trans crap out and have no money left to build it.
That's my .02 for what it's worth
