45% overs and ARP's this weekend
05lly2500hd
(903)293-6026
Feb 16, 2008
473
45
Texarkana, TX
sounds fun.........not. I hate tearing her down, so much stuff atop.
Hey Trent,
What is that in the first pic, behind the turbo? Looks like a locking dipstick for tranny?
05lly2500hd
(903)293-6026
Feb 16, 2008
473
45
Texarkana, TX
would someone point me in the right direction to where the strikes are coming from? LOL
Seems there's some beef, maybe just play. But I do have popcorn and coronas ready............to do some reading.
13,765
834
got both sides tore down last night , not to hard but a little time consuming .
I got all the head studs on the drivers side done boy thats time consuming :baby:, it took longer than tearing down . but will get the rest of the studs in tonight, swap tips , re-install injectors and put back together hopefully i can get it done tonight .
You already do the tighten and loosen 3 times deal too?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Ya torqued/ loosend/retorqued 4 times according to ARP's instructions . just did it 1 bolt at a time . heading back out to work again , looking like it going to be a late night . still have to put my dual fueler on too :eek:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Right on Trent:D Good luck this weekend:hug:
The bolts? Or the hold downs themselves?
Bolts for the rocker bridges, Superdiesel was doing it years ago:D
Studs would be better,But I think stock bolts are metric equivlant to a grade 5 ( junk ) I run grade 12.9 bolts on mine
You can purchase a set ARP from Greg Houge IIRC
13,765
834
You can purchase a set of 180k psi ARP bolts from Summit, Jegs, etc too.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Oh, i thought you were talking about the injector hold downs. Those are both stock on my motor, but it is tore down at the moment, ill look into that. I doubt ill get studs but ill look into the bolts. On Edit, how much are the arps?
TrentNell
Jul 7, 2008
7,543
slc tuah
trucks almost all the way done :D, just need some plumbing parts to adapt the dual cp3 to my MITUSA plumbing. just wish i could fire it up already , but I'm really close . should be able to find what i need tommarrow. talk about a big job , i have made pretty decent time , so far i figure i have about 18 hrs for injectors, head studs, and dual fueler install , hopefully wont have but a few more hours left unless i find a problem once i can fire it up :baby: because we did have 2 cups lift that we had to re-install and 2 cylinders that filled with coolant as a result just from there being coolant left in the block .
I cant thank my freind Matt Larson enough , he has been alot of help !
13,765
834
That's awesome news, Trent! Hopefully everything goes smoothly tomorrow. Good luck getting it fired up again! I look forward to hearing about how your track times and dyno numbers react to the new mods. :coolspot:
