45% overs and ARP's this weekend
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Nice! Trent Best of luck with everything
i would start stretching the bolts right in the spare block:D You pulling the motor or leaving it in?
its staying in the truck , just studding it nothing else , figured it would be dumb not too do it being that far tore down already to do the injectors .
TrentNell
Jul 7, 2008
7,543
slc tuah
Hmmmm I must have missed this. LOL I can't keep up. Did you make a thread on it? See any benefits from it??
have not yet had time to really test it but yes i had a thread on drive pressure reduction methods and it is one of the things i am trying I will update the thread when i have more info on the diference . switched from a 14cm cast housing to a 16cm stainless housing . Also the twins in my avatar are a test set from nathan but waiting to get the big charger back in the truck so i can test some more .
13,765
834
Not sure I thought the 625's were the $$ ones , either way i just got the standard studs nothing fancy . let me know if i'm wrong so i can fix the thread name :eek: .
Yep, the
625s are the $$$ ones. I think the standard ones are called ARP 2000. Just wasn't sure which ones you got. Have fun with the install. You doing the one at a time method with the engine in the truck?
ARP2000®: An exclusive, hybrid-alloy developed to deliver superior strength and better fatigue properties. While 8740 and ARP2000 share similar characteristics – ARP2000 is capable of achieving clamp loads in the 215,000-220,000 psi range. ARP2000 is used widely in short track and drag racing as an up-grade from 8740 chrome moly in both steel and aluminum rods. Stress corrosion and hydrogen embrittlement are typically not a problem, providing care is taken during installation.
CUSTOM AGE 625 PLUS®: This newly formulated super-alloy demonstrates superior fatigue cycle life, tensile strength and toughness – with complete resistance to atmospheric corrosion and oxidation. ARP is the first to develop manufacturing and testing processes for fasteners with Custom Age 625+. Best of all it is less expensive and expected to soon replace MP-35 as the material of choice in the high strength, super-alloy field. Typical tensile strength is 260,000 psi.
Iceman56
Jan 19, 2009
867
Madison, SD
Sounds good keep us updated. Some day I might grow up and get a big set of twins too :baby::rofl::rofl:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
add some billet holders too:happy2:
I dont think i would do it if I was planning on pulling it this winter JMHO
TrentNell
Jul 7, 2008
7,543
slc tuah
maybe , i got a freind who might have a set of hold downs for me , I dont want to turn it up with dual CP3 at the end of the year and have the head lift and end my attempt :rofl: , plus i will re-use them in my build . i figure with the dual fueler boost will be 70 psi or so .
Yep, the
Yep and even taking the hammer to the firewall :D
TrentNell
Jul 7, 2008
7,543
slc tuah
Head studs+Dual Fuelers=Bent Rods
Good luck
some guys bend them and dont have much to show for it at all , I atleast might have a 10 sec time slip to show for it and maybe some wins in the biggest race of the year racing with the big boys ....................... if the stars align that is . and I think they are already shortend so its enevitable really that they fail .
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Just thinking Trent:D Might want to swap out the cheap rocker brige bolts with some higher grade bolts maybe even the ARP studs
9,906
152
Any bolt supply place should be able to hook you up with some. Also ARP sells studs that are the same pitch/size as the stock bolts. Simon may have the p/n. Or you could shoot them a call with the dimensions of your bolt and they may be able to help you out.
