A buddy sent me some info
"I believe New RPO code L5P, Denso fuel system, continental ECM, 445hp/850tq, functioning ram air hood."
Numbers aren't correct FYI
Not tooooo far off. But offSince you can't say what they are...how far off are they??
Sent from my SM-N920P using Tapatalk
Curious what all the heat shielding is covering! The (what i assume is valley charger exhaust housing) shielding is much longer from front to back!? Is it still a single charger?
Is there any chance of them going back to push for a quick tune update after seeing Fords numbers released?Not tooooo far off. But off
They've been pulling that trick for years. It is part of the reason Ford will have more power on paper, but get their ass handed to them on the hill climb tests.GM will probably lie about their numbers ( on the low side ). The 15 and a half and 16 are putting down more power than the earlier LML's and GM never said a word about it.
That, and I think Ford lies about their numbers on the high side.
GM tends to have their motors tested to SAE specs, which are a worst-case test. That way, when they say it has "x" power, it means it has at least "x" power. Since they have been doing the SAE ratings for so long, if they didn't for the new one, I suspect more people would cry fowl ("what are they hiding? why can't it pass SAE tests?" etc) than would buy it for the biggest power numbers.I agree there. But why does GM do that? From a marketing standpoint, wouldn't it make sense to boast the "Best In Class" numbers?
I think eventually most heavy repairs on these trucks will be cab off.
