Nice work.
Now ya need to hook up efilive and start logging some pids while ya play with the brake and P/N wires. All those important position values can be logged, along with VSS pulses and cruise related parameters live, which will then tell ya what mode the ECM is in.
I run the LMM's in stand alone with nothing connected to the P/N circuitry and not notice any torque limiting. Nor with a T42 wired up, until I hit the speed limiter conflict..
However, there is some gear related torque tables that might be coming into play, depending on what gear the TCM is telling the ECM it believes it's currently in. That would make sense with N pin overriding the CANbus data.
Be interesting to see what it thinks it's doing at 40mph or so. Need more data...
