12.1 @ 116 :d
paint94979
Beer Nazi
Sep 18, 2006
11,715
in park i commanded 180mPa and the pump held almost 13psi? I assume i need to drive the truck to get an accurate reading?
paint94979
Beer Nazi
Sep 18, 2006
11,715
WOT run... went from 13psi down the 4 psi then once in 3rd gear it rebounded to around 11psi. Lift pump has been ruled out
13,744
817
Typically, MPH is considered a good indication of HP. Judging by your trap speed, you have the horsepower to run an 11. I think you have something else going on that is slowing you down. What are your shift points set at? Are you having long drawn out shifts? I know it has been asked, but are you sure your converter is locking when you want it to? If you haven't already, maybe try logging converter slip just to be sure.
paint94979
Beer Nazi
Sep 18, 2006
11,715
One thing that is strange is 1/8th mile and 1/4 mile MPH don't add up I'm gonna do return test tonight. See what happens
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Track Times
I agree with Josh. I think you have something else going on. My truck(stock motor) will run high 7.70's 1/8 without nos but at 86 best. It only runs 12.40's 1/4 at a best 106. You have the power your just not using it. Jeff
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Im with Josh as I stated before Id look long and hard at your converter as its a common cause of slow 1/8ths. Maybe dont get all pissy and just check it. You cant be 100% sure something is working unless you log it everytime.
9,905
151
i have that problom:( you will be happy to know that im going to spray the crap out of Abby next season:D
:rolleyes:
Nick, rule out the lift pump and do another bottle test. If all is good, I'd drop PW like slim said and see what happens.
