I have a customer that has managed to break a piston, but not in a way I am familiar with. The cracks are between the pin and the crown, but do not extend into either. They do not show on the underside either. The is some discoloration of the metal, but not conclusive of overheating. Very strange.
A quick run through the Thermal Analysis on the computer says that a loss of oil cooling could create a ring stress issue. That is, the center is hot and expanding while the outside is cool and contracted. But there is no clear evidence that oil cooling was lost or inadequate.
I am going to use some die penetrate on the cracks before I dissect the piston so I can see the extent/depth of the cracks.
I am told these pistons have seen several seasons and I am told some 900 or more passes at 1000 HP. I don't know the compression at this time.
