s400 on my duramax
Diesel Addict
Apr 24, 2008
70
Idaho
I have a custom s400 off my 12v that I am thinking about putting on my duramax an was woundering if I would still be able to tow with out high EGTs with a good tow tune
here are the specs
5" inlet
4.25" v-band comp outlet
2.5"/63.5mm inducer
3.6"/91.5 exducer
I think its 83.5mm inducer on the turbine
T-4 .90 a/r
juddski88
Freedom Diesel
Jul 1, 2008
4,655
119
Chesterfield, Mass.
it will work, it'll spool nice with the .90 housing but i run the 1.00 housing on mine (not sure what the higher rpm difference would be) and my boost doesnt drop off till around 4200 rpms
Diesel Addict
Apr 24, 2008
70
Idaho
Sweet,will I still be able to tow,casue I use my duramax to pull my 12v around in the summer to all the sled pulls,when my trailer is loaded it probably weighs around 12k
Diesel Addict
Apr 24, 2008
70
Idaho
also should I keep the 90AR on there for towing or should I put my 1.00 AR on?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Ok so now this might be a dumb question but would you rather have that s400 or would you rather have twins
Technically what you have is a S464.
Twins can spool quick and have a nice top end. A single can spool quick or have a nice top end, or anywhere in between.
Diesel Addict
Apr 24, 2008
70
Idaho
Ok, well my torq converter has a stall that is close to stock,an im wanting to bump it up to maybe a 1900 or 2k stall
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,149
Wilmington NC
www.mydieseladdiction.com
That charger would be great for DD and street driving. For more performance I would go bigger on the compressor and you would still be able to tow fine. I tow another Duramax behind my truck with a 5.5" inlet race cover on a 75mm compressor, with an 83mm turbine in a 1.0 housing. I also played with a .9 housing for a while and that is what was on it for the numbers in my sig. Have also towed with an S472 with a 1.1 AR turbine housing with no problems.
Diesel Addict
Apr 24, 2008
70
Idaho
How much bigger would you go on the compressor side?Also I have a s480 do you thinik I should put that on there or is that to big for DD an towing? an have a custom s477 with a 100mm turbine but the compressor is shaved to fit in a 2.6 class,
juddski88
Freedom Diesel
Jul 1, 2008
4,655
119
Chesterfield, Mass.
you looking to get rid of the custom 2.6 turbo too? was it also built by Gillette?
in addition:
i think the 480 is too big for a stock motor dmax, slow spooling, and pretty unusable.
i like the S64X i run (464) but you can go to a 66 or 68 compressor wheel with that same turbine side if i'm not mistaken.
