Oval Piston Roll Call!!
Kramer
46
Hornell, NY
Finally got my truck running last week with .040" over, 15.75:1 cast oval bowl pistons. Ran great for 300 miles, now I'm having injector problems. Should be around 800hp once I get the injector problem straightened out. Not the best fuel economy, but obviously nowhere near broken in, probably haven't even seated the rings yet. I'll report back after I get some miles on them.
quinton
1,883
Granbury Tx.
I've got around 40k hard miles on mine. Ran most of it with a Danville 72mm now have S475. Ready for this years season to start to see what the truck can do now.
rgullett83
1,608
Illinois
I have about 80-100 miles on mine since I got it running before Thanksgiving, been at the body shop ever since. Hopefully I get it back soon
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Almost a 1000 miles on min . Went 15.5:1. Smokey pig on start up on these low 60 degree nights. Did a compression check last week on passenger side. All cylinders was at 300. Does this sound right?
3,682
236
I think the cam plays a large role in cranking compression. I have 16.5:1 pistons in mine, but a stupid cam, and I see 350 PSI. So if your cam is aggressive, 300 wouldn't be out of the question. It does explain the smoke.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I am running a social af9100 with 150% injector .
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have 16:1 with reliefs in my truck. About 100 miles and so far so good. Will update as I turn the tune up and get some miles on it.
moparkxracer
2,309
33
Out and about
picture.php
I had 1500 miles on mine before blowing an oil pump. The Pistons went back into the engine when it was rebuilt.
Fingers
Village Idiot
1,713
84
White Oak, PA
The pressure you will see will depend greatly on the length of the connection to the compression gauge. The longer the hose, the lower the indicated pressure. Each cc of additional volume reduces the effective CR by about 1/4 point and thus the indicated pressure on the gauge.
Reactions: 56taskforce
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Is there a length of hose that is considered to be some sort of "national standard" or "accurate" when doing a compression test?
