Oval Piston Roll Call!!
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Correct me if im wrong but the adaptors with the valve in them that hold the pressure should still get you to the same point after so many revolutions? So let's say the first one gets to 220, second, 260 and so on. Just curious John.
13,599
632
Yes. If your adapter has the schrader valve in the tip, the length of your hose will only change how long you have to crank on it to get max pressure. Crank until the needle stops moving.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Putting my motor in now that has 16.5:1 .020 overs. will just be waiting on injectors after Saturday to have fire. can't wait to hear them.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Ok. But the adaptor needs to be same length as glow plug with valve at vary end correct? The adaptor I used did not go down as deep.
ctodd36
101
Otego, NY
Waiting on the machine shop as well. Running your .020 overs at 15.5:1 a Hamilton 192-200 cam, Hamilton pushrods and springs, heads are getting a valve job, lb7 cryo treated crank, keyed cam and crank, 100% overs. Plus all the mods in my sig. Hoping to hit a good high hp single charger number. These pistons sure do look pretty tho!
Hey what did this set up make?
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
Good timing for this to bump back up. I have just tore down our puller engine with 2 seasons on a set of forged .040". 26 pulls and 18 dyno runs. Half of those at 1250hp and half of them at 1500+. They are still mint condition. We will be re-ringing just because.
Sent from my XT1585 using Tapatalk
ctodd36
101
Otego, NY
This is great news I’m excited for my new motor to see its longevity with these pistons !
Fingers
Village Idiot
1,713
84
White Oak, PA
Very nice.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
What’s the idea behind oval bowl forged pistons? I understand they make for a much stronger piston which is needed for the cast version. But are people cracking the standard bowl forged pistons? I’m not being critical at all just curious if there’s maybe another advantage to the oval bowl that I’m missing.
Thanks.
Fingers
Village Idiot
1,713
84
White Oak, PA
Thanks.
Take a strong piston and make it, well, stronger.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Cool. I can appreciate that.
Has anyone cracked a forged piston in a Duramax?
Has anyone ever done a back to back dyno of round versus oval bowl at the same compression ratio to see if there is any difference?
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Here is what sold me on the oval design. Many guys had cast pistons break on higher hp applications. So most had to run forged pistons. Now many guys are running cast oval pistons with hardly any failures. My truck has beat on these pistons the last 2 years. This year we was around 1200hp. There is a lot of great info on how and why these pistons hold up on these in older post.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Oh believe me Ne-max I’ve read all of those threads that I’ve seen over the years. I’m sure I missed a few though. I am definitely a fan of the oval design for cast pistons. They have certainly proven themselves to be stronger then a round bowl cast piston. My question was simply why do it on the forged pistons also. I guess the answer is simply it works good on one, might as well do it on all of them.
56taskforce
1,074
51
Time for this to come back to the top.
Building new and looking for more info on these. Also curious about thermal barrier coating John uses is it worth it?
MarkBroviak
DMax Junkie
May 25, 2008
2,076
363
Danville Indiana
Mark, is that CR considered relatively high for a "race engine" or is that about where you like em for high performance (1000++hp) duramax engines?
Yes, it is a touch higher than most would do for a race engine but this was actually supposed to be the street motor for White Lightning a couple years ago and ended up in this truck because why not. Makes it that much sweeter!
