LBZ Porting/Polishing
yellowchevy
1,913
59
Louisburg, KS for now
Got the compressor side all done today. Just need a few parts to show up and then its assembly time!!
Yellowchevy
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
Can't stop looking at this thread!
Stay patient my friend!
Russell is working on me a super stocker and we will be doing back to back dyno testing with oh for results
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
Right on clrussell. Lot of Russell's around.lol... On goes my patient hat.
Haha..
I've changed my mind about 27 time already but pretty sure we are going to stick with a super stocker.
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,506
LA
Haha..
What options are you getting? BatMoWheel, Fingers Vanes, high Flow Turbine Wheel.....
I'm looking forward to your review/feedback
Corey
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
Corey
Wetzel wheel, port and polish, hx 40 down pipe and whatever else Russell thinks I should do.
yellowchevy
1,913
59
Corey
10 blade turbine wheel requires machining and believe Corbin is cheap!!:thumb::roflmao::hug:.
I'm looking for a good back to back comparison so I don't want change a ton. Being I'm going to use Corbins pickup I'm making him a good deal!!:thumb:
Ideally I'd like to
1 - dyno/boost test bone stock as it sits
2 - dyno/boost test ported/polished w/stock comp wheel
3 - dyno/boost test ported/polished w/wetzel comp wheel
4 - dyno/boost test ported/polished w/wetzel comp wheel & HX40 downpipe
But we don't have that much time!!
Yellowchevy
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
Ideally I'd like to
Yellowchevy
As soon as my wife gets to the lisence office and tags my jeep I'll have plenty of down time on the truck. I'm tempted to bring it up and drop it off for a while.
And yes I'm a cheap ass
Big Chris
2 Duramaxes> 1 Duramax
Mar 30, 2010
361
46
Rives Junction MI
Ideally I'd like to
Yellowchevy
I'm looking forward to seeing your results. I really like my LBZ turbo. I still haven't put a lot of miles on it but I'm very happy with my decision. ( I had Russell port and polish, rebuild, 10 blade turbine wheel and 63 mm compressor wheel) My truck is a poor test case because I had a non functioning stock turbo (stuck veins) and I'm not running enough fuel to really push the turbo. Normal driving it has stock like boost and lag. EGTs seem a little lower but when you get out of the throttle they drop much faster than stock. Exhaust braking is similar to the stock lmm turbo was. Not quite as aggressive at lower rpm levels but it feels very strong at highway speeds. It sounds like a 6.0 power stroke whistle. Noticeable in the cab but not obnoxious at all. Again, I'm running it just about as quietly as possible because I have the stock intake and am running a 4" Silverline exhaust with muffler. Straight piped and a metal intake may make it quite a bit louder. Again, Russell idoes great work and is great to deal with.
minerigger
2,660
Casper, WY
10 blade turbine wheel requires machining and believe Corbin is cheap!!:thumb::hug:.
Ideally I'd like to
Yellowchevy
Sure ya do. He had a jeep to drive remember lol
yellowchevy
1,913
59
I'm looking forward to seeing your results. I really like my LBZ turbo. I still haven't put a lot of miles on it but I'm very happy with my decision. ( I had Russell port and polish, rebuild, 10 blade turbine wheel and 63 mm compressor wheel) My truck is a poor test case because I had a non functioning stock turbo (stuck veins) and I'm not running enough fuel to really push the turbo. Normal driving it has stock like boost and lag. EGTs seem a little lower but when you get out of the throttle they drop much faster than stock. Exhaust braking is similar to the stock LMM turbo was. Not quite as aggressive at lower rpm levels but it feels very strong at highway speeds. It sounds like a 6.0 power stroke whistle. Noticeable in the cab but not obnoxious at all. Again, I'm running it just about as quietly as possible because I have the stock intake and am running a 4" Silverline exhaust with muffler. Straight piped and a metal intake may make it quite a bit louder. Again, Russell does great work and is great to deal with.
Hey Chris,
Glad to see you're enjoying the turbo and got it back together. I know it took longer than you were wanting and you battled a fuel problem but glad to hear its running!!:woott:
I could use an LLY, LBZ, LMM, and LML for at least 6 months to try different setup/variations!! I guess I just need to buy an LMM & LML that I could swap different turbo's into!!!:roflmao:.
Yellowchevy
