LBZ Porting/Polishing
yellowchevy
1,907
57
Louisburg, KS for now
I've got threads on LLY's & IHI's, why not one for LBZ's!!!
I just shipped one out Monday that got a batmowheel & porting/polishing.
I've got one right now that's getting a 63mm compressor wheel, 10 turbine wheel, stock vanes, new bearings/seals, ported/polishedd.
Yellowchevy
yellowchevy
1,907
57
LBZ with the batmowheel before taking apart.
Machining the exhaust housing!!
Marking out the up pipe ports.
Up pipe ports opened up.
Turbine side smoothed out.
Yellowchevy
yellowchevy
1,907
57
Started on the other LBZ. 63mm comp wheel, 10 blade turbine, ported/polished, stock vanes.
Rotating assembly
She needs to be opened up and a good cleaning to flow more air!!
Opening up the turbine side.
Opened up, just need to transition it and do the up pipe ports.
Yellowchevy
Awenta
4,090
CT
I think you just like things that shine :) :hug:
Aug 3, 2013
893
Arizona
Man those lbz's must sound unbearably sexy with these turbos in it.. Put a bigger down pipe and an intake on there and that would be even better
ScreaminDuramax
Sep 19, 2013
345
Torrance
I should've done this while my engine was out. Didn't want to drop the coin on the Danville quite yet, but this would've helped my overall power :mad:
yellowchevy
1,907
57
Thanks guys, it means alot!!!:thumb::thumb::hug:
Artists have canvas & I've got turbo's!! haha:roflmao::roflmao:
I look at it as artistic work, how much can I alter to get good flow & yet looks great:D.
Yellowchevy
