Home made race twins , Finally running !!!!!
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Long story short , I had to back out on my MPI kit , funding fell way short and out of necessity had to build my own setup , I am no fabricator so be kind with the scrutiny I do it out of necessity not because i am good at it :eek: I am not totally happy with how it looks but i chose all the routing to maximize flow and not around cosmetics so for now unless i change the "charge pipe" to suit my like for looks this is how it will be setup .
specs
S475 ( 75mm/83mm/.90A/R) / S510 ( 95mm/109mm/1.45 A/R) / 50mm wastegate
reversing the intercooler flow, y bridge will be on the drivers side instead of passenger , still have to plumb waste gate for the top turbo and build the intercooler tubes and modify the y-bridge but i have made some headway .
paint94979
Beer Nazi
Sep 18, 2006
11,714
no one is going to care Trent what they look like:thumb: that S500 is ugly though:spit: good luck i hope you exceed your expectations with this truck
TrentNell
Jul 7, 2008
7,543
slc tuah
Its a big bitch thats for sure :rofl: Its should look a bit better once the compressor cover is powder coated black !
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Where is the Y bridge? is it turned around and I just didnt see it?
Man that turbo is big:D I like the lil turbo facing that way:thumb: Hard to tell how much room is there to fit the intercooler pipes... but I like it
13,597
628
Why you reversing the intercooler flow? Doesn't seem like there's much room to snake the cold side pipe down into the valley between the secondary turbo inlet and the coolant pipe, fuel lines, wiring, etc on the drivers side valve cover.
It'll be interesting to see how the setup works for you.
