Forged Piston
Mar 27, 2008
178
Sheridan, IN.
Have Forged piston been proven reliable for a daily driver? What is a ballpark price for a set not coated and installed? Also what is the likely hood ti will trash your block if you crack a piston?
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
I heard there is a truck out of Merchants that is fairly high mileage with forged pistons.
The cost numbers I've heard are about $1,200 a set plus rings.
The stocker LB7/Y's seem to hold up pretty good under 800 hp and with the right tuning and injectors.
To Install a set of pistons without doing the whole shabang might not make good sense.
It would be a good time to put some rod's and stud's in as well.
If I owned a shop and you asked me to install a set of forged pistons, I would say it would cost you about $4,000 out the door.
To pull one of these motors and disassemble it to change pistons is not a Saturday project. It's a real big deal and lot's of hours. I think GM charges 30 hours just to do a injector change on a LB7.....@$90/hr..could be off a little but it cost a lot of Time/Money once you go inside. My numbers are open for debate.
Trippin
SoCal Diesel
Aug 10, 2006
663
Actually the Mahle forged piston kit, which includes rings and pins is $2700. The skirts are already coated.
Ross and Arias sell for much less but require double the amount of piston to cylinder wall clearance over the Mahle. :(
Noreaster
2,910
42
Cape Cod,MA
So....looking at the cost of new stock pistons, rings, coating & cutting it seems that the money difference is close to the forged price.
310
im looking at resusing my stockers here in a couple months
plan on cleaning the soot and carbon off them and get then dyed for surface cracks.. before i have guy cut them to ~16:1.
if they fail im most likey will be putitng forgde in the engine...
if properly setup i can see fordge lasting in a DD setup
i was kindaly reminded you cant use ferious base checking stuff on none ferious metals DOH!
thanks guy
Blueox03
Aug 12, 2006
668
Jackson County, MS
thanks guy
Dude, get a mac, it spell checks EVERYTHING! and it doesn't get AFU from porn....
13,599
633
Do you still sell forged Mahle pistons? I didn't see anything about them on your site.
Trippin
SoCal Diesel
Aug 10, 2006
663
No failures yet.
I'll be more comfortable recommending them after we have 20-30,000 miles in a daily driver/performance application.
