2nd gear launches
13,599
633
It won't lock until it reaches the right speed (around 25 mph I think).
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
Kat what are your 60's with a 1st gear launch and what are your 60's with a 2nd gear launch?
1.7's with both first and 2nd gear launchs.
I can tell you that Ralph cut .28 off his ET by having Pat flash the 1st gear delete off his truck at Famoso :D
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
It should actually be easier on the trans (if built) than launching at the same RPM, boost, etc in 1st gear. The engine has less mechanical advantage through the trans (higher ratio) which means less torque multiplication. The converter is going to build more heat so you wouldn't want to sit there for very long like that but I don't see any reason against it. 2, 4, 6 skip shift is the best setup. It can be done.
Brayden
9,903
149
Brayden
I agree with everything Brayden except for what's in red.I disagree with this being the best set-up. It is totally relevant to your tire size, gearing, trans mods, HP etc...
4th to 6th would be useless for me. I shift into 5th at the 1000' mark and If I could stretch the rpm's and keep the fuel a little longer I would stay in 4th.
Bluemax
Sep 25, 2006
846
Missouri
And it has....with stock tires and wheels anyways....:hug::D
Bluemax
Sep 25, 2006
846
Missouri
You can do it however works best for you. 1-3-5, 2-4-5, 2-3-4 Just depends on the traction, tire size, engine mods....ect.:)
Alligator
Nov 9, 2006
1,919
47
N. Idaho
Brayden
Thanks Brayden.
9,903
149
I see where your going with this Kevin. The 2,3,4, is enough for the 6 speeders-just put it in M-4 and pin'er with 1st gear deleted!
