28.8" OD Drag Radials
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
Nitto 555R's, 305/40-18's are perhaps the best choice drag radial for slippery tracks where you have to drive to the track. Most drag radials are 28" or smaller, and the compound is too soft for the road.
Might be old news, but I probably would have got these if they were available last time I bought drag tires.
1,623
Why in the world wont just ONE tire company make drag radials that are a reasonable height for our trucks? How hard would it be to create something to fit a 16" wheel?
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
Cause these trucks are suspose to be for towing and not racing :rofl:
1,623
Theres a market for everything. You'd think the tire companies would have at least have heard about diesel racing....:rolleyes:
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Tires
Firestone makes a tire just over 30" tall that is dot legal. They make it in a 8.5 wide and 10.5 wide. I think they will work great and will be trying them sometime. The only problem is price. $280 eh.:mad: If I need them which it seems now I will. I will be the test mule I guess. Jeff
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Tires
Yep 16" Look up racetires.com I think thats the web site. Jegs has them also. You can go there and look up the specs. They have to order the 16" but they can get them. Jeff
J Spruill
bringer of truth
Mar 30, 2008
770
i have these nittos .not that impressed with them.however i have not tried heating the tires up before launch i will try that next time out.tires are very stable in daily driving,at least when they are on. also bought them from a buddy used for 250 bucks so i cant grip to much...lol...
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
Unlike M&H and M&T's, the Nittos only work well when heated, since they are a much harder compound. But they are safe on the street. I've driven at least 25,000 mi with them on the road, and only hydroplanning is an issue.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Tires
That big HP Cummins you have Jess needs all the traction you can get. Did you ever put a roll bar in it? I was wondering about the suncoast event if your running super street? Thanks Jeff
1,623
I just looked those up. They are actually a Coker Tire product.
10" wide: http://store.coker.com/1000-16-firestone-dragster.html
8.2" wide: http://store.coker.com/820-16-firestone-dragster.html
Good lord, those are expensive. Are you sure they would work on our trucks and be safe? Theres a lot of weight for those vintage tires to hold up.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Tires
From what I seen at jegs they have a stiffer sidewall then a ET street or M/H. I think they would work well they are just $$$$.
J Spruill
bringer of truth
Mar 30, 2008
770
well as far as suncoast my plan is to run prostreet.i do have a bar installed.as far as big hp i am not sure about that.currently i leave the line wuth more than a 900 hp setup and my 60fts are aweful.like 1.9s.i am working on being able to leave with more usable power.if i back it down to say 750 setup it runs great just lacks on the top end.still a work in progress.i hope to hae my new motor completed by suncoast event so i wont have anything to worry about if this current one decides it has had enough...
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
I have to ask the stupid question sorry...
Do these trucks leave the line so "soft" we can get away with the 40 series tires? Are the converters that soft outta the hole? thats what? 4" of sidewall? No forgiveness, the tires just break out under big HP no?
I know these things are heavy is that why we head towrds the shortwall tires?
Learn me please this seems backwards.:confused:
J Spruill
bringer of truth
Mar 30, 2008
770
i actually would prefer more sidewall but since i have to clear brake calipers i must have at least a 17inch rim.not many options for tires in that area,then when you factor in weight rating the list becomes almost nill...
