28.8" OD Drag Radials
Drholliday
286
Gresham, OR
Would a 15" rim work on a Chev/GMC and can you find them? lots of good sizes in 15 inch. more sidewall as well.
On my 16" rims I don't have the clearance to have sticky weights on the middle of the inside of the rim without them hitting the the front brakes, I really doubt any 15" rim would fit on the front of these trucks.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
IIRC, I looked into this awhile back and couldn't find any 8X6.5 bolt circle for a 15" wheel...Maybe someone makes them now...
A company in Peoria? Glendale? Near Phoenix can make 'em... can't memmer the name though?
$500 a rim custom, rear aluminum up to 15" wide. (I want to try them in the rear only with a mini tub (2") and 16-18" x 34.5-36". It'll take up all the space from rail to outside of the bed)
If you need the info PM me, I have it in the job file at the shop.
On Edit- IIRC nothing under 16" will fit on the front unless a guy converts to smaller brakes. With a drop spindle nothing under 17" will work unless you mod the spindle 1/4"-3/8".
9,903
149
I was chatting with someone once about converting to a half ton front hub assembly so a guy "could" run a 15" tire and smaller brakes but I dunno how much work that would be or if it would hold up to the HP/TQ we are throwing at it.
The Neens
BFD
4,596
Monrovia, Ca.
Thanks James...I was looking a few years back for Dad's 2WD dually, ended up with some treaded M&H's, now we'll use the Nostalgia 16X12s...I'd still like to know the name of the company...
1,623
Who in their right mind would downsize the brakes on these trucks just to run a slick? There's far too much weight and inertia to use 1/2 ton brakes, IMO. Only way I can see it is if you're talking about running high-$$ aftermarket setups.
