22.5 tires and wheels on the Kodiak
kodiak
Sep 25, 2007
178
40" tall
What do you guys think???
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Looks Awesome Jerry ,
How do you like the ratio now , pretty nice isnt it .
Mileage should be better too .
Congrats it looks so much better with some bigger rubber under it .
Johnny
kodiak
Sep 25, 2007
178
Now if there is a Guru of EFILIve that can figure out my speedo......I can send you the tune. Thanks for the compliments! She rides so much better than before.
kodiak
Sep 25, 2007
178
Picture for reference
Talked the better half into posing next to one of the tires to give you an idea on how tall it actually is
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Well I can tell you by owning a kodiak , you can use a tech 2 to recalibrate your speedo . This can be done on 4500's but not little 2500 trucks .
Joe at PPE did mine back in the day before he figured out the speed governor. It was driving me nuts only being able to go 75mph .
It was the only way to stay off the speed governor , he set it half so 30 was 60 . Not sure if you can do with efi , Im sure you probably can . But I know you can use the tech 2 on 4500's to adjust the speedo . You just need to figure the math out and adjust . And find someone that has one and knows how to use it .
Good Luck ,
Johnny
320
jerry all the tunes i have form you have you setup and cal'd for 41" tires and speed govenore removed...
cell H0101 should be this number 103464
40" tires and 5.13 gears
kodiak
Sep 25, 2007
178
I had already set the H0101 to 105253.....That was the calculated ratio for pulses per mile....I must be going the wrong way because it is still off by about 13 MPH. I will try the new number Adam, and see if that makes a difference.
What do you think of the rims being painted??? Not sure if I like the factory grey color, might go black.....just not sure if it would be something I would like or not.
320
Nice , Adam you can do 4500 speedo with EFI ?
There you go Jerry
Johnny
yeppers :D
bigger tires less turns/revs per mile... smaller number
rims black :D
9,903
149
B.C.
I think black would look really nice. Also will help hide the brake dust!!
The truck looks good as is though!!
