Alignment issues
CentolaCCSB
It will probably break
Nov 2, 2015
322
Mass
So as the title says im having alignment issues ( i think ) so here goes..
I had my new rims put on 20x12 -40 offset after trimming bumper and adjusting my stock torsion keys on level ground i went to get an alignment at my local town fair tire. Couple days later i walked out to my truck after work and noticed my front passenger side had some positive camber not a whole lot but enough to notice. Brought it back to town fair and they went over the print out with me and argued with me saying its fine yada yada yada, demanded a re alignment and that didnt fix anything. I checked the ball joints myself and they seem fine. Hopefully someone will have a solution or advice
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Does it feel loose or sloppy in corners?
Pretty sure the ONLY way to truly adjust camber on these trucks is with the eccentric cam bolts that hold the UCA to the frame...they typically get adjusted with an alignment...and I bring it up to tell you to check the bolts that hold the UCA in place and double check the tq spec...make sure its not moving around...if it is, it will need another alignment
5,060
picture of said "camber" will help as well. if you were turning into the spot and still had the tire turned, it can look like postive camber. best way to recheck is to back backup, straighten the steering out and pull back straight in, then get out and look.
CentolaCCSB
Nov 2, 2015
322
Mass
No slop in the wheel or anything rides straight and steering wheel is straight.. Ill check the bolts out. Now that you mentioned bolts being loose it got me thinking the other day i hopped in my truck after warming up i threw it in reverse and as soon as i rolled backwards i felt a thud or a "popping" feeling under my feet
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Technically factory specs wants a little postive camber. I believe this is due to the camber going negative with a big load in the back due to the short arm/long arm design. With your wide, offset tires the shop should have set it more close to 0° camber. How I do it at least.
CentolaCCSB
Nov 2, 2015
322
Mass
Crap also as im typing all this and reading what you guys are saying i have noticed since i put the rims on around corners between 30mph and up the steering wheel will kinda jerks back and forth, dont know if thats related or not
Awenta
4,090
I had mine done three times in two months at town fair. Destroyed my two front tires within a couple thousand miles.
Went and had it done again at a real shop and it's been good since then. Needless to say they won't be doing my alignments anymore.
CentolaCCSB
Nov 2, 2015
322
Mass
Yeah town fair sucks... Asked the manager if he needs me to go back there and align that bitch myself cuz clearly your employees cant
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
i had the same issue with mine. i had my truck aligned in vegas when i installed the new tires and alll new steering compenents including ball joints.by the time i made it to ND they showed pretty bad cupping. i was pissed. i took it to some dudes in town that claimed they were the best in ND......and you know what they did a DAMN good job. havent had a problem since.
find a different shop
CentolaCCSB
Nov 2, 2015
322
Mass
Thats almost perfect, def wouldn't cause tire wear.
I know according to that its almost perfect but you can see the camber from the front. I talked to the guy who works on my truck sent him a few pics and i guess the upper control arm needs to be adjusted
Bustedknuckles
Honey Badger
Sep 25, 2010
1,309
32
Hagerstown MD
I bet what happened is they didn't get the UCA bolts tight enough and its out again. They are hard to get to to properly tighten. I hate doing alignments on Chevy's and i own one. LOL
CentolaCCSB
Nov 2, 2015
322
Mass
It doesnt even look like they touched them, the frame and such was coated with por15 and you can still see it on the bolts and nuts for the UCA. Looks like im taking her elsewhere to get it fixed for good... Last thing i need to do is chew up these brand new meats
Ridin'GMC
I like red
May 20, 2010
619
MA
Most town fair shops blows. Everyone i know who had their alignment done at various town fair shops have the same issue. Look around for a well known alignment shop. It took me a while to find the right shop to do mine because of my wheel setup.
5,060
Based on that pic, they never were touched. In all reality, I wouldn't have touched them either. Caster looks good for road crown (counters the pulling affect road crown gives), camber is in spec and all I would have done is fix the toe.
Hop under there and look for the sliders to have moved.
Also, a pic of what you consider cambered out would still help
CentolaCCSB
Nov 2, 2015
322
Mass
Yeah i can try to take a few pics of the sliders and the camber
CentolaCCSB
Nov 2, 2015
322
Mass
The sliders are those 4 half moon lookin things on each CA right?
