I am currently putting my short block together with Carillo rods. Using my stock crank, just had it polished and mag'd. My question is what kind of clearance should I have between the 2 rods on the same journal? It seems the cap is a little tight going on. It still turns but there is no play when you move them back and forth. I know with small blocks I have always been able to get them to tick side to side. This one I cant and just wonding if it is too tight. I have the caps on the correct direction, rods on the right way with flat sides touching and beveled side against the crank.
