Will ATI Super Damper make for smoother idle?
07keo02
Oct 5, 2011
399
Phoenix, AZ
So if you were to just slap an ATI on, how do you know how to "time" it for just like a stock motor? Their website also states that they can make for a smoother engine because of the fact they become an integral part of the crank once pressed on, rather than being a somewhat loose fitting damper like the stock style, which makes sense.
dansdieselp
Diesel Tuner
Apr 3, 2009
99
Marengo, IL
The hub is keyed so you can't mess that up. There is a small dot on the hub and balancer that shows the offset bolt hole. Just line them dots up and put bolts in.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
That's how you balance solid stuff is drill hole and add mallory if needed, or leave the hole hollow. But something that self balances centrifugally I don't think you can adjust it.
Sent from my PC36100 using Tapatalk 2
dirty_max
815
eureka il
oh i thought you knew that, then why are they so bad minus the fact that they are a little heavier than stock? also i was talking about the empire kit when i asked about the hole drilling
07keo02
Oct 5, 2011
399
Phoenix, AZ
Yeah, I was just saying that they are filled with silicone fluid, but I don't know it is all the way down in the center. The empire kit drills a circle, half of which ends up in the balancer center, half in your crank shaft. Then the "pin" slides in to fill that circle, parallel inside the crankshaft (like a key), instead of our current pin design that sticks up perpendicular.
07keo02
Oct 5, 2011
399
Phoenix, AZ
I personally don't know that they are that bad, I just don't like the idea that they retain the slip fit perpendicular key design.
dirty_max
815
eureka il
oh gotcha. there are a lot of people on other forums that claim it is like the worst thing you could do is put a fluidampr on your dmax
EDP
<<<< Miss The Ol Girl
With our crank pin kit you must use an ATI or Stock. As far as vibration or harmonics the crank pin will not help with that. In most occasions when we have customers stating of small idle vibration is early signs of a pin failure for both performance upgraded applications or stock work trucks.
The crank pin kit is easily installed with basic tools on a average install time of two hours worth of work. (takes more time getting to the front hub then actually drill and install)
07keo02
Oct 5, 2011
399
Phoenix, AZ
So basically, that loose fitting stock damper can move around a tiny bit, even without shearing the pin entirely and will start to create vibrations. Mine actually bent the pin, but did not shear it. I just got a new pin and a used balancer with no damage to the keyway. It seems that an ATI would help with a smoother idle, because the stock is a looser fit and doesn't become one with the crank.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Instead of making a new thread I thought I'd just bump this one...
What's is the take on using an ATI super damper on a stock engine???
Can you just bolt it up and go?
I've read and heard no, and yeah...
Hot COCOAL
Jun 9, 2012
4,433
And WTF?
My GM reman didn't come with a balancer....
So it would almost seem implied then that ALL LBZ balancers are the same? And if that's so, and ATI made a damper "for" the specific engine designations, shouldn't you be able to just bolt one up?
Or did they just screw up and forget to put the balancer on there before they sent me the engine?
But I can't imagine GM balances EVERY duramax engine, so I would think that they just use a default weight based off of a mean average weight of the rotating assembly...
Want are your thoughts?
3,733
305
You can use a Super Damper on a stock motor. My brother has one on his bone stock LB7 after it sheared the pin and spun the stock balancer.
GM uses a generic balancer for all the motors. The crank itself is balanced (kind of), so you can swap a different balancer on without issue.
IIRC the LB7 and LLY use one balancer, and the LBZ+ use another. So you can swap things around as long as you stay in those ranges.
And for what it is worth, my brother's truck idles much smoother with the ATI damper than it did with the stock one.
Porno Joe
513
South of Pittsburgh
^X2 what he said
01-05 are the same an 06-10 are the same. Not sure about LMLs.
yes GM used the same balancer. been doing it for years. We had tons of old small blocks from the 60-70s and they are had the same balancer on them.
I bolted a Fluidampr on my motor. zero issues in a year
dirty_max
815
eureka il
I have been running my fluidampr for quite some time now with zero issues. with quite a few hooks/burnouts at almost 5k rpms without issue. I say that and will probably regret it later, I have a hook this weekend on a really loose track haha
