Who makes the best dual fueler?
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Looking for the best dual fueler setup for an lb7. I'm not looking for the most fuel as I will be running 2 stock cp3s for now but rather the best belt alignment, lines, hoses, connections, controller. Things like that.
Thanks
Jesse
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Very interested as this will be my next purchase after the turbo. Also how about the most complete kit I don't want to have to chase down little parts
770JOHNNYW
Sep 16, 2009
791
Gainesville ,Ga
Thanks
Jesse
maybe ats??? hell who knows anymore i put an ats on an lmm and it seems ok:confused: ppe's are supposedly better with alignment issues but who knows
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
I think they are all about the same, about the only difference is the size of the plumbing. MPI's is a fair amount cheaper for sure. Nathan actually had a working set several years ago and it went on Nasty Girl, took him a while to get someone to make his controllers. We actually put on a triple set on Max'd Out for a little while but took it off and went with modded pumps on a double set up.
5,791
Ive been told the ats kit overdrives the cp3 at higher than stock rpms and can float the pistons. Can anyone confirm that or is this hear say?
I went with ppe, have not ran it yet but for the price dan got me, i couldnt pass it up
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
I'm shopping too, but I've already got a second pump. I think I read somewhere McRats sells a kit?
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Unless you changed the tuning, no need for twin pumps. Not to mention the stock motor won't hold together. Plenty of fuel can be added with just tuning, I promise.
Sledheadxp800r
Dec 13, 2010
1,151
CT
I know the motor probably won't last to long after that. I'm already on the hunt for motor parts
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
Was this not proven wrong. Also how does 2 pumps blow a motor it is the tuning that does it. Two pumps will just hold the rail on the larger tunes.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
Thats the problem is you will actually hold the rail pressure your commanding. It's not that putting dual fuelers will blow your stock motor just because you put them on.
