am I reading this right? you cant run work stock if you have a lift pump? and Im doubting ill make it, I havent worked up the courage to cut a 6" hole in my bed for a stack!
Hmm what class will I fall in? ?
More than likely brackets , but if you can get close of enough "quick diesel" (12.0 index) is a super fun class to race in , heads up racing with a 12.0 cap on et !
Sweet!! You got.any turn ups that will go over 6" tips? Or will I need some flex?
Can't wait to see your truck pull, that thing is sweet!
Is there a pre reg? Or can we do it when we get there?
Jason you don't have to run a stack , a turn up tip on the exhaust will suffice , i have one you can use if you need it ? and i know you can run work stock with a lift pump .
good luck to all involved this weekend, drags, dyno and pulls:thumb::thumb::thumb: wish i could be there, im retired for the rest of the year, going on a cruise during the nationals, and game up over the winter. Good luck everyone.
seemed to be a pretty good night for everyone, except for trrent... :hug:
