Got one with sound compiling now.
Today was full of highs and lows. Highs, engines performed flawlessly. Good temps, pressures, spooled well, and both smacked 4500R a couple times. The new props hooked up better, so 6 blades helped, but drives are still too high.
Answered the question "What would happen if PAS triggered by accident?" The TB tripped by accident on port engine, loaded up and making 35psi boost. Then prop cut loose and she smacks the limiter. Followed by a huge bark and a What The Hell, out of my AU buddy.... I was only surprised that the Vibrant clamp and tubing held it..
Then after a few more attempts to get on plane, we heard a bang, and stopped to inspect everything. Found nothing until we put it on the trailer. That's when I noticed, oil leaking from side if port drive. Believe a broken gear tooth matches that noise...
Sent from a reclined position using Tapatalk
