for thoes who tow with twins and consider there truck streetable how does it work out?? to much heat?? any down falls??
Don't think anyone answered this. All I can give you is my experience having owned two daily drivers with twins, an LB7 and my current LBZ. There is much less heat, that really is the heart and sole of the twins, lower EGT's. I have a friend with an LBZ with a stock turbo and EFI tow tune, MSRP 4" exhaust. We have about the same size travel trailers, 28' and they weigh within 500 lbs of the same weight, around 8,500 loaded and wet. If we tow up a grade at exactly the same speed using the same tune my egt's will be 200 degrees cooler than his. I have much more power with the same tune do to more air. I can't think of any downfalls for towing. In my opinion twins do not do well on the dyno, for some reason I can never get even close to the boost I can get on the street. On at least two occassions I have dyned (old LB7) in the mid 500's, had dodges hit 100+ more hp than me and absolutely smoke them on the track, not even close. I'm talking half a second. These weren't heavy lifted trucks either. I limit my boost in my LBZ because I don't want to do head gaskets or something worse if I turn up the power too much. I like it right were it is, fun to drive, very streetable, quick and great MPG.
