Pretty hard to argue with Tomac, he has the trophies to prove it. Obviously I'm a twin guy, to me streetability is you wouldn't be afraid to let your grand mother drive your truck, (reasonable tune of course). My 07 has a totally stock engine, lift pumps, exhaust, tranny and co-pilot, sleeves, braces, and spring clamps for racing. I drive the same tune I race with and it gets 17.5mpg stop and go and 21+ freeway. Rob says it 550 +/- hp to the ground but I've never dynoed it. It runs 12.6, 106.8X darn near to the 10th of a sec everytime. Race weight with me in it is 7200 lbs since I have a B&W goose neck hitch which is heavy. Never seen EGT's on the track go above 1300 degrees. But when I tried towing with this tune, I set a code for high boost pulling an 8K trailer over a Mtn pass which I never understood as it wasn't even 40psi at the time. I have my boost waste gate set at 43psi tops. I believe it all in the tune, especially for twins. If I romp in it hard it lets out a little puff of smoke clears right up and and is gone.
Acceleration is instant and pulls hard all the way to the stops.
I bent all the rods in my 02 mainly IMO due to me beng very naive. I had dual fuelers, big injectors and a tune was bad for that setup and which I drove it on before I got it retuned. I actually think I hurt that motor before it ever saw twins, I had so much junk on it and raced Kennedy up that MTN in Montana with EGT's way way up there, I was running an A2000 at the time, propane and 50/50 H2O/meth.
Blew head gasket on studs. Very dumb Ass of me.
