Can you please describe where and how tapping the hole in the block pumps oil to the turbo im confused on where it is at
There are several running twins w/ the s475 ungated on the LB7s that have no problems.
Im running a cheap Tial knockoff on my LBZ.
This should help
I started with a 1.10 Ar exhaust and a 50MM wastegate, now I have a 1.32 exhaust and no gate. I'm thinking about putting the wastegate back on, I'm making 62 pounds of boost on my race tune :ralph: , but I don't want :shifan: with headgaskets......
he had it from his twin build that had a different atmosphere charger with a tighter a/r on the exhaust hsg and wanted to dump the drive psi faster with the bigger gate. I use a 40mm jgs gate and i have drive psi within 1-2 psi of boost and drive psion my lb7. Vgt turbo trucks drive psi wise will be different(a little higher)why did you decide on a 50mm wastegate? I see that bako is only using a 38mm, but you are both using the same size charger (1.32ar) any benifits to using a bigger one?
i noticed that some of you guys have changed your big chargers around a little just wondering what everyone has tried, what characteristics did each one have? I'm currently looking at the standard s475 from bw airwerks with a 1.32 ar but it looks like there is some different turbine size options around just not sure what to use. i may need to go with a smaller charger to since i will be running the stock ihi and it will need to pull over 10,000lbs alot during camping season.
I have not really read much about twin kits with BOV's except maybe a couple MPI's, is it hard to bark the big charger? I know the only time on my LB7 I can bark the stocker is at the end of a pull or parking lot burnouts when the truck has no speed to keep the motor spinning. What Im asking is do daily driven throttle chops or full throttle pass throttle chops bark these?
