thats the same turbo setup i plan on doing to mine this winter! the 1.32 and T6 should be a good setup for daily driver?
are you going to put some heat wrap on that hotpipe?? also, were did you run your oil return line off the the turbo, just into the oil pan? i was thinking about running it to the oil fill tube tube.. easier to get to and drill/tap, but it might be to high? probably dont want the return line to run up at all... nice job on the tubing fab!
