You can run 9's on 1 charger and maybe some spray. If you ad triples you add weight and more stuff to break! Don't mind me l just like when trucks with 1 charger whoop up on twin and triple trucks:woott:
I bet a 4088 wold get you to 11.8 and a 4094 could get you to 11.2 (consistently, at altitude), both are easy to spool, easy to tune, easy to twin, put either of these on a t4 and you wont have to worry about drive pressures either
Hmm i don't think a turbo that big is gonna be consistent enough for what i want to do, and be hard to spool at the line, especially at elevation in Billings for example. But i could be wrong, never drove a truck with one, that's the reason why i started this thread, to get more advice. How does yours spool? Have you ever ran it with stock injectors?
I say do a gt4202r with a 1.01 housing then add a wastegate and spray the living heck out of it. Pat's truck went 10.59 with that charger and stock sticks!!!! Just be a badass and do that!!!
Oh, I kept thinking super street................... Well in that case the boring 371 should be all you need for that.
Well, there are plenty of turbos that will work for that, that class is very tight and it's usually always on the driver! I'm sure you know that.
Put The 4202r(74.7mm) and make a tune that will run 11.90 all day(tow tune). After you get bored of playing with the children you can turn the tune up and blow some chit up!!!!
I'll be quiet now:rofl:
What charger do i need to run 9s on a single? Obviously a Garret, But how high will my EGTS be? Do i need to worrie about drive press? Do I really need spray? Or just a maybe?? how fast to spoool?? I want to lose some weight and really like your idea:thumb:
