**Turbo Talk**
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The HTT was the first charger that ran 11's on a fuel-only Dmax. I know, I was driving. :D
Now it is improved. It has a better turbine housing for more power. It's great for towing, yet has enough top end for the dragstrip or sledpulls. It's a journal bearing, wastegate BorgWarner S300G chassis that has been heavily modified by High Tech.
I believe it's the most underrated turbo for our trucks.
paint94979
Beer Nazi
Sep 18, 2006
11,715
I agree with you for sure Pat, the HTT can be rebuilt alot cheaper and easier than the GT Series turbos but I know I love mine:D
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
I am counting on you never going to the track;)
You will be the one tuning my truck so you will make sure it makes a little less power
I am not scared of Brian I think a 12.8 will be a bad run for me with the new turbo
De-tune yours, never!
We'll run yours until it pops, then I'll dial the tune down a tad, and load it into mine.:rofl:
:D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
You might want to up the ante a bit.
If I would ever get my lazy azz to the track and learn to drive this pig...:D
Plus, Brian is only .o3 from a 12.8x run anyway..
Paint nailed it!:)
I was at firebird tonight, didnt see you :D
I think im pretty much at the limit of the stock turbo, 40 psi is overkill. need to mess with caltracs, and tire pressure.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Duramax_JP I got your message over at the DP and ill respond here.
Personally the stock turbo was not meant to spin the way the Cheetah upgrade allows them to do... Plus I am not fond of FPE but anyway my 4094 is an awesome turbo from its low RPM sound to its ear piercing mid/full throttle whistle. I have ran a best of 12.32 with it and I can bet there is .2 or more that I will be able to drop while still running my LLY CP3/Modded Regulator.
And to compare stock turbo spool up to an aftermarket turbo is irrelevant. Sure my VVT spooled quicker but who cares? The second my 4094 gets to about 10 psi it pulls crazy hard. If you go with a 4094 you'll have a 12.2-12.3 second truck on single CP3 and stock injectors NO PROBLEM. Say you later want to go to a twin setup the 4094 twinned with a 4718 should support 850 RWHP
I dont believe spool is dependent on the turbo and more so on the tune.
I had the HTT on and it would spool at 4000' faster than a VVT
It was too fast if thats possible and I had to tone it back.
Nick you would know this if you would try different tunes;):D
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
what size was the HTT? from how highly everyone talks about it im pretty sure thats what i will be going with. just not sure about the size. 66mm sounds good but 71mm sounds even better :D
super diesel
<<<< Under Pressure
I find the elevation is murder on the spool up and overall power making ability of the charger too. I lose about 50+hp and 100+trq going from lower elv. (1K and below) to 5K+ elv. when in the 500hp+ range, and it gets worse as the power goes up and the elv climbs. In a way, I'm kind of looking forward to the move down lower (300ft) in the end of March.
My friend and I did a short no boost take off last night in a abandond area. He's running a stock motor with moded reg with a A5K on a LB7. I had only 1 pump going (not driving both) and the GT4202 with the 1.01 exhaust housing. He shot about 100 ft out in front until mine spooled (play times over). I cought up to his speed right quick but the lag was up there. I'm about 1G heavier too. I'll be towing at my GVWR max here in a month or so with the set up. I'll post back the towing ability of it and my findings compared to the A5K I use to run. Even with the lag up here, I love the GT42. When it goes, it ready for a rumble (even in my heavy truck at 5k+ elv).
Oh, just for info. I bent rods at 576hp and 1102trq on an LB7 (twice). I did compression checks at different power levels on a cool motor leading up to this power. At this power the compression suddenly dropped to around 290psi at my elv. (5500ft). Maybe tuneing has some to do with it, but this is not high torque. The rods lasted another 40K bent before I changed them out (ticking time bomb). The heads started to leaked at the 40K point (I pulled the motor 10K later). I'm thinking that when head studs are needed, so is rods. You can make much higher HP for a brief time (as so many has found out as well), but your risking it big time. Just info and my findings. We need some others to do this test as well who thinks there safe after a big power run on a stock motor (actual findings, not "but I think it's ok").
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Simon, what did you do with your HTT, didnt you go bigger on the 01' :confused:
Sold to Bronson
Dunno what size it was, That was years ago
I think all aftermarket turbos are great:D
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i think 71mm would be very laggy and to much for a t3 pedistal for drive pressure ,in most s300's the exhaust wheel is usually a 71 mm as well , i would stay with the 66mm and ad the twins when you need more air .
Sep 10, 2008
1,072
Morehead City, North Carolina
What were you running when you bent the rods on that lb7?
Righteyeblind
712
Fairbanks, AK
gt4094r! I love mine it spools fairly quick at 5000' and I hit 38 psi up here. I havent towed with mine yet but I hear it is great. They make good power, sound and good for daily drivability. I just upgraded it from a 4088r and there is a lot of difference. Same DAish at the same track I ran .34 faster then my 4094. My 4088 would only make 30psi too.
