Sorry, I should have read your sig closer. I noticed that you are a CC/LB. I don't think that will go 11's without a lot of work. I have the same issue with my truck (CC/LB). At this point I would be happy with mid 12's. I do not want to have to gut the thing to get the weight down for a few Saturdays of fun.Also on a side note would love to get this big monster into the 11s I think it'd be pretty funny to see the faces made if I did get it there. I know I wouldn't be the first to do it but it sure would be fun
I'm in a similar boat as well on the weight thing. I'd have to drop the hitch, step bars, subs, drop to a smaller tire, drop the spare and so on. But well that's a LOT of work won't want to do that till I'm dual fueled, built motor and so onSorry, I should have read your sig closer. I noticed that you are a CC/LB. I don't think that will go 11's without a lot of work. I have the same issue with my truck (CC/LB). At this point I would be happy with mid 12's. I do not want to have to gut the thing to get the weight down for a few Saturdays of fun.
I do too much towing to remove the hitch. Too lazy to remove the running boards, etc.I guess I will just have to make up for the weight with a set of big twins and dual CP3's
...then rods, keyed crank/cam, cut pistons, etc., etc.
FWIW, I have not been able to run Pat's race tune because of snow and ice on the road (and the 4 studded tires), but when the turbo lights off on the 175hp tune, man does that thing run....:coolspot:
Keep in mind twins will only allow you to pull in an exibition run if you plan on hookin your truck ever
So I'm going to be sticking with a single for simplicity sake and now I'm stuck between Cheetah (68 or 71.5) and the HTT S366. Already have an aftermarket Downpipe so the HTT would mean selling it and selling the stock turbo which would offset some of the much larger price tag of the HTT but a PITA...so just trying to make my mind up
TThe install of my HTT wasnt that bad, I took my time and I enjoyed learning how. Ive heard nothing but good about the cheetah as well, youtr choice, I got my HTT for less than the 71.5 cheetah.
Thanks for the heads up. I know to start spraying the up pipe bolts with PB blaster like now haha. Any other words of wisdom?
