Mike you have converters for the LML? You have clutch packs, Hydraulic mods and whole nine yards?
Are you able to control the line pressure electronically with the new Alli?
Yes.
I wonder about HP Tuners they gave up at the LLY?
Makes me wish I had just bought another LBZ. Especially since I just found an 07 CCSB loaded with low miles for $27,500.
Has anyone found an easy way to fool the EGR yet, like a fingerstick? I would be happy just running a 50 horse tune with a 3" down pipe and deleted EGR.
Not lookin to drop a grand on a tuner that I cant/wont use all options included.
So get the XRT Pro for $660ish....
As soon as I do that PPE will release their tuner! Thats my luck...
How much for the CTS monitor? Any combo deals, CTS and XRT Pro?
I would wait a little longer.
The long term solution will be something like an EDGE box but with a full ECM in it. Reflashing the OEM ECM is going to get harder, and harder as time goes on.
The box will "see" the commands from the real ECM, and reply to the ECM with fictitious sensor data. Then the "box" will do the actual fueling control. This way, the OEM cannot detect or defeat the box. It will see a stock engine running normally, no matter what the engine is really doing.
I just wish I knew somebody who knew enough about electronics to assist me in building one. This will be really big if somebody pulls it off. It will work on all CR diesels with just connector changes. It won't even matter how many cyl the engine has.
The Solution, in my mind, is simply a replacement ECM. Open OS and tables. Stock ECM be damned.
It isn't a hard project. Just not enough market to cover the R&D. Then there is the moving target presented by the OEM with the constant model changes. Other companies like GM, Bosch, Holley...... are just so far ahead of the game it is a long way to catch up.
Rough example:
To cover a given year, you would have to sell 1000 units at $3500-$4000 to break even. 10,000+ units would drop you below $2000 but I don't think you could get below about $1,400 a unit in any limited market year.
So is what y'all are saying to pull the ECM out of a truck say an lmm truck and put it in an lml? Could it be done?
you'll need to put LMM heads/injectors/fuel system on it first...
