Okay so I've got the truck running good only thing is after sitting awhile its hard to start. I have to pump the gas pedal a bit and then it fires up with a cloud of whitish grey smoke. It has stock rail pressure and pulse width for cranking and idle. Rail pressure is around 5500-6000 psi. Should I raise it to 8500 psi or so? What about pulse width? Do I need to lower anything for cranking or raise?
