Tuff Country owners
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
You have my number :D
so russ what bs are your 17s? Also what about me running 315/70/17s
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Unless that half inch screws me completely. I might order spacers just to be on the safe side. Dont wanna put the lift on and not be able to fit my wheels and tires :happy2:
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
It will rub (Front bumper) with torsions dropped and my 17's, when I hit a bump while turning, or backing up and turning on the street. But I do have them dropped all the time. It is 41.5" from wheel well top to the ground in front (TB's Dropped). And 42.5" wheel well to ground rear (2in. block). You could get 3-4" blocks instead of the 2" and be able to crank the TB's for more lift. The CV's are negitive quite a bit (See my pic's in DP's Garage).
TwoTone
Mmm tits
Apr 30, 2008
193
dont get anything less that 4.5bs with 17s or 16s. I did for a while and I had to run a spacer and still wore on my 13.5s on 17s w/5" bs
I cant seem to keep mine aligned either. Really need money to put my AAM under the truck:mad:
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Do you have a tuff country lift? Also do you mean don't get anything with less than 4.5" bs or do you mean with more bs i.e. my h2s that have 5.5
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
When talking about BS the higher the number the closer to the truck the hub mounting flange is. I would stay with a 4.5 BS. I wouldn't run a 5" inch BS with a 16 or 17 inch wheel. A 5" BS would put the tire right up under the truck, flush with the fender. If you run a 4.5 it will push the tire out from under the truck and rum about 1 inch past the fender depending on tire.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Well I like things that aren't supposed to work :D
burkhard runs them pulling just fine on that lift and russ runs pyos to race. Ordering mañana
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Talked to Tony B and Tuff Country today and went with the one piece kit wit .4" spacers just to be safe. That's te exact setup Tony is running and Russ has the same one. The TC guy said if it were his he would do the one piece you just need a buddy to help lift it
edit: spacers are only $75 plus ship thanks Tony!
13,765
834
While you're at it you should get some spacers for the rear end to make the tires all even.
