Sure, it'll get costly but you will have quality. What's wrong with the input bearing? Do you even know how to check it? Spray the heck outta it with brake clean, then put a bit of gear oil on it, if it's quiet, it's good to go.
OK James I want sure if all parts were OEM or if some were knockoffs. That explains alot of the price difference. I dont want chinese shit either. I also dont want some junk reman found on google as well. Thats why I was asking if anyone has dealt with a particular company that has good remans.
So I assume all of Merchant's are OEM parts? If so I apologize for saying his parts were high. Its understandable now. Even then I dont think he has all the parts I need so I may have no other choice than buying a reman.
Well, I'm sorry for trying to be helpful and I clearly missed the part where the OP complained.
Your case looks really bad though.... I hate to say it
You kind of over did it. You might want to build a transfer case in as bad a shape as this one, but most professionals would not. Also , you cannot make pure judgement calls on pictures and advise someone unless it is totally clear.
Advising someone wrongly can cause them to spend uneccessary money because they believed you. I try to be very carefull so that does not happen.
Just checked Monster Transmission. They have ALOT of complaints about trans not working more than 1k miles.
I think its Transfer Case Express for me.
Thanks to all for the input. Im not rebuilding. Im buying. My kid doesnt need to goto college anyways...lol.
I don't completely disagree, but I am a professional and have actually built hundreds of transfer cases, some in as bad shape as that, when I have had no choice except to basically salvage just a front case half and go new on everything else, not always cost effective, but when the customer expects a certain level of quality and I stand by my come back number of zero.
I did try I provide guidance as noted by the description of how to check a planetary, how to remove the input shaft snap ring.
You will note how I have never chimed into a discussion on the operation of an Allison as it is not my expertise. I have some knowledge but not enough to chime in to a thread.
The problem here is that nothing I say is necessarily wrong, but that there is no way for me to "win" my case, since you are Duramax royalty and I am a minion.
Fact is, I pissed you off when I noted that that first pic of the tone wheel that was blurry and looked bad and the subsequent 4 showed that it was in fact not that bad and you won't let that go.
Of course, it takes a big man to admit when he's wrong and no one is perfect, right? But you can't do that can you? Similar to when you hung me out to dry on that LML build last week.
Anyways, enough ranting I'm done. I'll bow out gracefully from this board and never comment again. Goodbye.
