traction bars...what would you run?
5,840
i coppied the ones on brians truck, these work pretty darn good, ive had caltracs on my dodge and they worked good too, havent been to the track yet since i put the new brian(hondarider) style bars on, but a i can definetly leave WAY harder with these installed!! thanks for the pics brian....:thumb:
I built those for brian and put them on but your welcome :D
oleshifty
Jan 28, 2011
any pics? :)
My cam/heads/headers are going in friday.... need to get the ball rolling on this axle-wrap issue.
Ryan T
1,007
CA
check the thread (Pics for Ruben).. mine look almost identical to the ones chevy1925 built for brian...
05chevy
1,086
Don't try 1 1/4 .120 wall 6' long with cheater slicks look a lil like this after 3rd pass
bobby
$Smokin_Duradog$
Sep 16, 2006
209
Goshen, IN
I put in traction bars went a very cheap route and they have held up great. I had issues with the rear drive shaft eating ujoints at the axle end. This solved that problem for me. I went to TSC( Tractor Supply Company ) bought tractor draw bar hiems and cut 2 sets in half to get 4 joints then slid I believe it was 1 1/2 solid steel bar inside them and welded all the way around. I bought square stock the same width inside as the hiems and cut a "C" shape for the rear axle and welded them on. I took my truck to the strip and ran 14.70s with it on 38"s and a stock motor. LoL! My bars are solid mount as well and are around 5ft long. I took it all off though to 4 link my truck front and rear.
Ryan T
1,007
CA
nice truck:thumb:post some pics with the 4 link
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
anyone want to build me a set of solid traction bars for around the price I can sell my Caltracs for? Definitely tired of the noise and don't have the patience to constantly dick around with adjusting them...plus not like I'm going to be racing a ton just want them to keep axle wrap under control a bit
05chevy
1,086
DOM I should have never went with DOM that light. Building 1 1/2 .250 wall about 18" shorter this time. U live u learn lol
Colt
Jul 23, 2010
523
If you want more iron under you than Caltracs check out Tony Burkhard's bar kits. He will talk you thru what you need and options of making or buying them done from my reading. The price of iron is going crazy so I'd get them bought if this iron price keeps going straight up it's going to be a killer to buy fab materials. I like Caltracs run them all the time just slightly flex when you grab them and jerk on them with your arm hard is where I leave them set. They sure help launch straight on the street and I have gas shocks and air bags on the rear axle too so it rides OK it does it's job so I live with the slightly rougher ride with no axle hop it's fine by me. I lube the joints every 2 weeks to help stop the rattle and squeaks with the all purpose lubes with white grease or etc...
