traction bars...what would you run?
jheyob
305
Okeana OH/West Lafayette IN
OK....
So help out with this...even though part of the question is answered.
Can someone help out with the physics part of the question? For example, is the purpose of the longer traction bars (sled pull type) supposed to help with weight transfer?
When you're pulling, the axle housing itself wants to rotate the pinion up towards the bed...so if you have a link mounted to the bottom half of the housing it will want to push forward (pretty much equal to the force of the pinion wanting to rotate up). When the link pushes forward and is connected to a point far forward on the frame, it will try to lift the front end of the truck...putting more force on the rear axle. The longer the bar, the better the point of application of the force on the frame, the more lift you get to an extent.
oleshifty
Jan 28, 2011
sorry to bring this back from the dead...but I have a 01 chevy with 5.5" block in rear, and a 1.5" add-a-leaf. Will caltracs work? Or am I stuck using a shorty-bar? (truck is mainly used for street/towing/drag racing)
5,840
i dont think they work 100% correctly with that much block under the rear. least thats why i didnt go with them. jsut got done building some 60" bars for my long bed. dunno how they will do at the track though, hope to find out soon. also built a few for some buddies, one of which took his cal tracs off to put these on (48" bars for a short bed), made his truck ride rough or they clanked around if he loosened them up. we are very interested to see what his truck will do at the track for a 60 ft now :D
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
I cut 1.75-1.79's all day with caltracs n 20's but they make ur truck ride like shit and make a lot of noise. im going with one up offroad traction bars as they seem to have a much more thought out design and address all of the negative effects i saw from the caltracs.
just done with noise and a rough ride.
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
set it and forget it. thats where im trying to be.
any way you look @ it, the caltrac is preloading the rear leaf, causing the rougher ride. unless you remove all of the preload by backing them off when not in use theyre going to affect the ride.
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
but then i pull up next to you at a light and what do you do? plus then you have the noise. :) i liked em plenty and sure there are other things you can do to stop the BS, but WHY?
billy mays said it best, "set it and forget it"
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
^ that was ron pepeil :thumb:
but they will still work find if they aren't preloaded at all as long as they're very close. soon as the back squats the tiniest bit the pin will come into contact with the spring.
no offense but i think a lot of people who talk down on caltracs don't have a full understanding of how they work. they aren't made to have preload on them 24/7 and too much preload will make your launches worse
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I like the concept of the caltracs, but I hated mine. Rode like crap, and noisy over speedbumps. I got really tired of it so I sold them and had longer bars made. I need a bit of weight trasfer to my back tires and thats what the new bars do. Hopefully make it to the track in the next few weeks. best 60 foot ive cut with caltracs was 1.74 on stock tires, so we'll see.
05chevy
1,086
I have cut 1.73 with 6' bars and 31's gonna see if I can better wuth slicks
bobby
BUST'EM 504
1,047
I really want to do a set but I didn't realize they rattled I knew the ride would be little worse got me thinking if I should even do them. I have cut 1.71 with street tires and springs clamped and a well prepped track. I just want to knowif they will be worth it
oleshifty
Jan 28, 2011
You guys with long bars...how are you mounting them on the frame side? Solid mounts or using a shackle setup to allow for 'travel'
Ryan T
1,007
CA
i coppied the ones on brians truck, these work pretty darn good, ive had caltracs on my dodge and they worked good too, havent been to the track yet since i put the new brian(hondarider) style bars on, but a i can definetly leave WAY harder with these installed!! thanks for the pics brian....:thumb:
