What's the hardest you've launched it? Y'all really think keys would cause that much toe in? The offset part I would believe but as I said earlier my buddy has exact same setup except he has kryptonite kit. Same rims, tires, lift.
The more backspace, the less toe in. It makes a dramatic difference.
I'd start with tie rods and pitman and idler arms.
17-18ish IIRC it was couple years ago... My buddies truck which had lift keys was going nuts on the launch I thought for sure he would wreck. He also had a stock center link with no braces, just tierod sleeves and lift keys. We couldn't get his cv even close to flat. My truck would go a little past flat. Not a fair comparison but it sure wasn't helping him either.
I can't really tell from your pic but the cv looks pretty flat. Can you get a shot of it a little farther back?
Id listen to this guy...^^^
Are you sure your buddies wheels have the same offset?
Tie rods look like they're going down from the centerlink.
Yes they are a bit
That's the problem. You want them going up from the centerlink. That way as the front end rises, they go almost flat.
For some reason I thought they where last time I was under it. Lol. I'm not sure how I will achieve that my t bars are lowered as much as possible and the rubber bump stops are barely touching as is.
With the bolt out of the adjuster you should be smashing the crap out of the bump stop... Some guys have even cut the stop down some to get even lower.
Same with your truck Jason.
Try putting stock keys back in guys. It may not cure it 100% but it will help.
Why do people go to leveling keys? Because they can't get any more height out of their stock ones.
Leveling Keys with the bolts backed out are probably the equivalent of stock keys with 8-10 turns. Give or take, depending on brand.
Sent from my DROID RAZR HD using Tapatalk
