I love the ride quality of the IFS but as far as a work horse, not so much. I'm not planning on putting a straight axle under this just yet so I had to replace some broken parts for now. After looking at it, upper ball joint and outer tie rod- passenger side, lower ball joint, outer tie rod-drivers side and both hub bearings had a little play, I said to hell with it all. I'm replacing everything on the front end.
I started by cleaning all the parts and then sandblasting them. I painted everything with POR15 so the parts don't rust up again.
I love this POR15. I use it on everything. So I decided to go ahead and paint the frame as well. First I pressure washed it all then went over it with a wire brush and knocked off all the loose crap, then washed it again and used compressed air to blow it all off. I ran out of daylight so it's not perfect but I'll get it better with my second coat.
Got everything in from rockauto.com except my CV shafts. Should be here on Tuesday. When I ordered the ball joints I went ahead and got "the problem solver" from Moog. Now that I got it I'm wondering if I should have just gone with the reg ones. This is offset to allow adjustment for camber/caster but I think I'm seeing more of that issue on lifted trucks. I'll talk to my alignment guy on Monday and see what he recommends.
I got both inner and outer tie rod ends and also picked up tie rod sleeves just for insurance.
I'm planning on having all this done by the 4th then it's time to start on tearing down engine related parts to install big air kit.
