LB7: The Rebuild, Ch.2 -- Building slowly
durallymax
Apr 26, 2008
2,756
Under The Hood
NAPA has a lot of things, I use them for everything on the farm, because its so nice and easy with Prolink and free delivery. But sadly for our engines, its kind of a lost cause unless you want a water pump or fan clutch. The rest is mostly Gm parts, even all of those stupid ridiculously expensive o-rings, you can try to use one out of an o-ring kit but its not gonna work 99% of the time.
Many of the gaskets and o-rings are reuseable as long as they are in good shape.
As for the cherry pickers/engine pullers, if you look closely you will realize that the are all almost the same thing. Mine is from Menards. It was like $120. Its identical to many of the others ive seen. I use it extended all the way out where it is only rated for like 750lbs and pull my motor that way, no issues with it at all. We use it for a lot on the farm, when it cant lift something, the back end of it wil come off the ground first, and thats when you just stack some extra weights on it so that you can keep lifting.
they can handle quite a bit. Just use them with care, and remember to turn the jack realease valve the right way, i screwed this up once and send my motor crashing to the ground.
1,943
The 41909 rings...are they cast, moly or chrome?
What grit hone do you guys recommend to use with that set of rings? Just going to deglaze the cylinders.
durallymax
Apr 26, 2008
2,756
Under The Hood
yea, stand thats what I ment. Thanks.
O engine stand?
I got mine from NAPA. Its a fancy one with a geared dealio to rotate the engine, and its collapseable which is great for storage, but if your like me, it serves as the resting place the the engine 90% of the year anyways.
I think mines rated at 1250lbs but it might be only 1,000. Its pretty shaky when the engines all assembled on it, but i dont get to worried.
1,943
James, if you want that Sears one I bought...Ill give it to you. Too expensive to return, and I have no use for it.
Went out and made up my list. Pretty long, but not overly bad.
1,943
Hmmm..thats how I felt two years ago, and look where it got me. Trust me, once you start, its almost impossible to stop.
Dazedandconfused
Lost in the diesel smoke.
Jul 26, 2007
225
Nothern Ky
I have another one I'm preparing to build for nothing but competition and a toy. Just want to keep my DD a little hotter then the others running around this area.:)
1,943
Couple pics. I didnt want to unwrap the crank. Merchant's machinist does nice work.
1,943
The pic doesnt tell the tale...the sides are cut straight with a .125 radius edge.
Got the rings today at my local speed shop, Johnson's Speed Warehouse. Perfect Circle 41909 -- $290! :thumb:
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
nice :thumb: i paid more dangit o well i thought mine we done with the same radius but maybe they used something smaller:confused: hopefully yours dont go together and you lose an injector after 4 days of driving it o and the oil return line ya the gaskets for those blow a fat one to mine is leaking bad gotta pull the turbo( i think) so i woild put some right stuff or gm silicone on it to make sure that b***h seals :D up-pipes are a dirty bitch to take on an off well the drivers one is anyway
1,943
Good deal.
Bearing showed up a couple days ago. Slowly but surely....
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
Pistons look good Tom, i wonder if that place will ship rings :rolleyes:
i was at Dustin shop last night got the front end taken apart. found 2 very nice size pieces of the engine. 1 was 1 x 1 in the other was like 1.5x3.5 both had spots where main bolts went through. cant wait to get her pulled.
1,943
Sorry to hear about it Justin.
Funny thing...my bearings came straight from Mahle (in a Mahle box).
1,943
I guess I dont understand your question. I didnt have to buy a new fuel rail. Im reusing my old parts.
1,943
Piston Ring End Gap-First Compression Ring - Service Limit
1.37 mm
0.0539 in
Piston Ring End Gap-First Compression Ring - Production Value
0.3-0.45 mm
0.0118-0.0177 in
Piston Ring End Gap-Second Compression Ring - Service Limit
1.35 mm
0.0531 in
Piston Ring End Gap-Second Compression Ring - Production Value
0.50-0.65 mm
0.0197-0.0256 in
Piston Ring End Gap-Oil Control Ring - Service Limit
1.20 mm
0.0472 in
Piston Ring End Gap-Oil Control Ring - Production Value
0.15-0.35 mm
0.0059-0.0138 in
Cylinder Bore Diameter - Service Limits
103.11 mm
4.0594 in
Cylinder Bore Diameter - Production Value
103.0-103.014 mm
4.0551-4.0557 in
Cylinder Bore Out-of-Round - Production Value
0.015 mm
0.0006 in
Cylinder Bore Taper - Production Value
0.015 mm
0.0006 in
Just had to put the ring gap specs where I could find them.
