Info: TCM tuning
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
How often do the 2 of you race
I have 100's of passes on my truck... Trans has almost 100k miles (ok 96k to be exact) and 4 years on it. Its had a couple bigger single turbos for 95k miles, and in the past 25k miles it has twins/injectors. I was a beta tester for EFILive 4 years ago so its had all sorts of stupid tuning done to it. Not to mention daily abuse and towing.
what kind of power are you putting down, and what kind of times have you run.
Just because I dont post every time I go to the track and make a big deal out of it like everyone else doesnt mean I dont work my trans hard or my truck doesnt make decent power. You guys can use some of your fancy calculators to see what kind of hp it takes to make a 7680lb (with me in it, race weight confirmed by scales) go 12's at 107-108mph in the 1/4. That was back in early 2006...which wasnt all that slow back then.
I dont know the power, my truck has never dyno'd well. Dyno's are a stupid way of measuring a trucks true real-world usable power anyways. It dyno'd like 430rwhp or something odd like that. Yes its actually a lot more hp than that. That was with 285 BFG's and heavy 18" eagle alloy wheels. Guarantee its a lot more than 430rwhp to push 7680lbs 108mph in the 1/4. :rolleyes:
The higher the power and the more passes you make the more your problems are going to come to the surface.
duh... There have been so many people that have had to refresh their trans at much lower hp levels than mine.
FWIW, I built a trans for my frined's 2005 LLY CC/SB. Its lifted on 35's. He runs an Aurora 5000 with a big tune and has drag raced it plenty of times. The trans has over 50k miles on it and its been flawless. You know whats in it? Stock replacement allison clutches, a transgo, and 1050 converter. Yep. THATS IT. No main regulator pressure shim, no converter flow valve, no extra clutches, no power packs, no secret squirrel, etc... Everyone laughed at me when I said I was planning on running that mild a trans with an A5k.
I guess Im just lucky when it comes to transmissions.
ben
IdahoRob
Jun 5, 2007
1,151
Josh, The 5 speeds and the 6 speeds react differently. I agree, you can not get a LBZ to stop defueling on shifts with the ecm tuning. You sure can with a LLY or LB7.
My own personal race TCM tune has just shift rpm and mph adjusted, that is all. I have tried adjusting everything on my own trucks in the tcm and have gone back to basically stock.
I have had a few customers with converter locking issues, that I have gone deeper into the tcm to try a band-aid, but understood the potential risks. Never have had a problem though.
This is a good thread. As Others have stated, ecm tuning can keep a tranny alive for a long happy life, or put the hurt on it. If the tranny is built correctly and the tuning is right, it's been proven to last a very long time in high HP trucks that get thrashed.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Just because I dont post every time I go to the track and make a big deal out of it like everyone else doesnt mean I dont work my trans hard or my truck doesnt make decent power. You guys can use some of your fancy calculators to see what kind of hp it takes to make a 7680lb (with me in it, race weight confirmed by scales) go 12's at 107-108mph in the 1/4. About 600-620hp
Ben, I wasn't accusing your truck of being weak or slow, was just asking. The original poster is trapping 115 and in the mid 11s - even if it's a light truck that's not easy on the trans. For the guys needing a refresh with less power than you (with the exception of ATS guys:rolleyes:) there is either a problem in their trans build or a major problem in their tuning. A truck that is 500-600hp and running 12s on bad trans tuning is going to be alot more forgiving to a trans than a 700+hp truck in the 11s. So you might have a TCM tune that does fine for 100K miles and 300 passes at that power level but will tear up a trans in a few passes at a higher power level. That's the only point I was making.
15,681
235
Good post Rob.
racinmike77
Sep 14, 2008
1,029
MD
Curious to know the person behind the slippers also. Would apreciate a quick pm.... Thanks,Eric
Dont worry about it, what everyone should worry about is looking at the tables in the TCM and making sure they are stock. I know its fun to blame it all on this "pink slippers" but he is not the only one with potentially dangerous tuning.
ZeroGravity58
1,401
51
Maryland
I am going to help you all out here.
There is a conversions table in EFI-Live, it is a folder and it is clear as day, it is above the information, top right of the screen.
You can use this table to import a fueling table, timing table, torque table and then play around with the values without screwing the real table. Then when you have the values where you want them you can copy it back into the real table.
This is also important for adding or subtracting values from two different tables, two tables that you might not think you can compare you can even if they are different tables in the tune files.
If you alter throttle based injection quantity it will screw up torque limited injection quantity, this is a fact, if you alter base torque it can alter the de-fuel on the shifts.
If you have a huge disparity in the main injection pulse width tables from mm3 row or in adjoining cells and you follow the de-fuel with the scan tool link you can see where you may have to add or take away pulse width to correct a bad de-fuel or a over fuel on a shift.
Most people make the mistake of altering the throttle table first to get more fuel without altering the main injection pulse tables, if you go down that path you might someday get a good shifting tune, you may never, but that table is the key to everything else in the tune, that tells the ecm where to look, that and fuel pressure base on the LB7/LLY ecms. That is your right foot asking the truck to do something and it responds by looking up fuel MM3 and from there all other tables link for timing, pilot timing, pilot pulse, etc.
As far as the transmission,
When you alter the tq values in the TCM you have now upset the request for a proper de-fuel, when the request is wrong you now have two problems you will be chasing. one is an incorrect request for de-fuel if you eliminate it in the tune or raise it up the defuel will never be correct, two is you may have removed some of or all of the ability for the transmission to make a clean shift without tying up three clutches at once.
The shifting is by far the most difficult aspect of tuning, it took me almost a year to figure out how it all works, now I spend very little time on it because it's easy for me to fix it.
Tony
Thanks for this info Tony. This explains alot I think most of my problem was with my TCM tuning as table D5196 was way diffrent then stock. The 1800 RPM row was copied and pasted for all the other rows after it. I always had a wierd part throttle shift and could never figure out why. Im not that greatest tuner but im guessing alot of it had to do with this table and it not requesting the proper de-fuel. D5197 was changed on top of that.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Let me ask this then. I changed my desired tq limitting values in my tcm to some what match the ecm allowed tq to rpm limit tables. At wot it still shifts like it did before just nice and crisp. At part throttle it still shifts nice and crisp but the truck seems to excellerate better at a lighter throttle??? Should I change it back to stock as it still defuels betwen shifts like it did before.
2,084
Hey guys, I already asked RacingMike, but I'll put a general request out, too. Can someone PM me the FILENAME of the trans tune in question, so I can check my EFI and see if its something I've run/am running in my truck? I DO NOT WANT TO SEE THE TUNE...just the name of it.
ZeroGravity58
1,401
51
Maryland
Im not a tuning expert (obviously or i wouldnt be where im at) but i would think the easiest way would be to look at table D5196 and compare it to your stock tune trans tune. They should look the same or be close to one another. Also check D5197 and make sure it says "all enabled"
