G-Max double sided Carbonite frictions are now available in C3 and C4. March 1 All G-Max kits sold will have Double sided C3.
We've also released a new "All Raybestos" trans kits. everything is slowly getting up on the site. We still have Much more to release
Parts included are:
C-1- Custom stepped apply plate, (8) GPZ C1 external clutches, (8) GPZ internal splines clutches with a custom C1 top plate.
C-2- Custom stepped apply plate with (7) C-2 GPZ frictions and (7) steels.
C-3- includes our (6) SCZ double sided frictions with no center slots and a pattern in the material to help retain oil to cool clutch when it’s not applied. (5) Custom steels with no center slots. This design works great in your daily driver, towing and even your extreme race conditions. SunCoast has also redesigned the apply piston with improved rubber compounds that are proven to hold more heat if the circumstances arise. The custom piston allows us to use our thicker spring apply plate that replaces the thin OEM one deflects from the spring pressure and causes a uneven surface for apply. This plate also redirects the oil to better lube plates from the inside out which lubes the entire friction rather than OEM style that lubes from the center out leaving the inter half of the clutch burnt. Top apply plate is also machined and included with kit.
C-4- includes(6) SCZ double sided frictions with no center slots and a pattern in the material to help retain oil to cool clutch when it’s not applied. (5) Custom steels with no center slots. SunCoast has also redesigned the apply piston with improved rubber compounds that are proven to hold more heat if the circumstances arise. The custom piston allows us to use our thicker spring apply plate that replaces the thin OEM one deflects from the spring pressure and causes a uneven surface for apply. This plate also redirects the oil to better lube plates from the inside out which lubes the entire friction rather than OEM style that lubes from the center out leaving the inter half of the clutch burnt. Top apply plate is also machined and included with kit.
*C5 clutches are
NOT included do to the fact they are normally good to re-use unless the unit has been contaminated by water or other foreign elements. C5 clutches are optional and can be added to our kit upon request.
Other parts included in kit are P-1 shim, lockup boost valve, a shim to shim pressure regulator spring/tool for easy installation. Full size TransGo shift kit.
This corrects common problems such as;
* Neutral under load, 3-4 slip, burned C2 or C3 clutches, sticks in one gear, won’t move after extended parking, loss of pump prime.
This kit includes smart clutch control valves for increased durability and Short-Crisp-Smooth-up shifts and kick downs/ reduces trouble codes. This is the most complete shift correction kit available and definitely the most reputable.
Suncoast Allison paper and rubber kit includes all seals, gaskets and o-rings required to overhaul the Allison 1000. We work directly with the manufacture of our seal kits, so any improvements/revisions are passed on to manufacture and our kits are upgraded to pass the quality on to our customers. We include a new spin on filter and new sump filter along with our billet filter loc to prevent filter from working lose and dropping out of the pump.
* Please specify whether shallow or deep filter is needed with purchase of kit.
* Instructions are included in kit and phone support is available as well.
*Core Charges for the C1 Pressure Plate, C3 Pressure Plate and C4 Pressure Plate apply.
Custom kits are available upon request.
Parts included are either manufactured or designed in house making it easier to tailor each kit to the needs of the customer and the potential of their vehicle.
